had a FWD chair for a week and for the life of me I just could not get the hang of that thing.
Just felt weird and slightly out of control all the time. I don't really understand why.
Simple physics. The centre of gravity (C of mass really) was behind the centre of pressure. Thats an unstable situation that wants to spin the chair around and face the opposite way. And it would do so without some electronics to prevent this. To try and stop this they use an electronic gyro. Which is like adding a sticking plaster over a wound. It usually almost fixes the spin out problem by adding "turn power" to the motors to keep it straight. But has to take over control from the joysticks input YOU choose in order to do so. So at times its using all or most of the turning power available already with "opposite steer" to try and stop its ass end from flying out wide. So its leaving non for you to use to steer. You feel this as the chair not doing what you tell it. Such as when accelerating and turning. And yes it feels horrible. I have no idea how on earth people that claim its great can NOT FEEL this. To me its patently obvious and it stops me ever wanting one as a gift. You can try to disguise the issue but you cant actually beat the physics thats happening anyway.
Front drive / rear casters = unstable platform. So introduce a slight turn and it naturally wants to increase that and the more it does, then the more it tries to increase the turn. So it really "wants" to spin around. And it tries to do so. Gets worse exponentially as you go faster. Cannot ever be programmed PROPERLY.
Mid drive is neither stable or unstable, known as neutral. Some of these have gyros. But dont need them once programmed PROPERLY. They neither tighten up a turn nor straighten naturally. It wants to continue whatever turn rate you introduce forever with no further input.
Rear drive is a stable platform. If a slope, bump or turn is introduced by terrain, or by driver its natural tendency is to straighten up naturally by itself. Just like your car. It "wants" to go straight. So does so. A gyro is pointless unless you are driving with switch non proportional controls. It already naturally does what a gyro attemps to for front drive chairs.
Or:
MID neutral equilibrium:
a state of equilibrium that is independent of a system’s displacements from its original position
REAR stable equilibrium:
a system, when displaced, experiences a net force or torque in a direction opposite to the direction of the displacement
FRONT unstable equilibrium:
a system, when displaced, experiences a net force or torque in the same direction as the displacement from equilibrium
