Postby expresso » 20 Dec 2016, 01:12
yeah - once you got black you cant go back :mrgreen:
i got the new Pl 8 - installed the Presets - it was set at 40A in the supply tab - i upped it to 50A like the first PL8 - so far so good -
we see when i charge with it - maybe friday -
i am even thinking with my indoor chair - when i change those lead batteries again - i may just add a cable and make a small ADD On for the indoor chair - i can do even just 15ah pack - one row - or two - and be good for 10 years indoor use
can charge once a week - i will wait till i get a new chair - then swap out batteries - use the lead from the ADD ON now - and put in my indoor chair - take the new lead from new chair and put in my Back up; chair with the ADD ON -
shouldnt have to worry about any new lead for 10 years - sounds good to me :)
i may get more 15ah cells - make another ADD ON - i have the feeling a few of my friends may end up with the 646se chair next - convinced them -
they are not going to do the lithium swap on there own - so maybe the most i can do for them is - when they want to take a long ride with me - i can have them use one of my ADD ONs - for that day - i would have to take it back to charge it myself -
i cant see no other way they will be able to ride with me - thats the least they have to do is use a ADD On - i think after a few times they get used to it - they may want to invest it in and PL 8 etc, - or just use mines - why buy the cow when you get it for free -
well see how it works out -
Postby shirley_hkg » 20 Dec 2016, 02:19
What is EC5 feature ?
Is it standard to all V2 models , no matter new or refurbised one ?
Postby Burgerman » 20 Dec 2016, 02:22
Stupid blue connector that I cut off and replace with anderson...
Postby shirley_hkg » 20 Dec 2016, 03:25
Burgerman wrote:While I am in teaching mode ! ! !
8-)
YES ! Please stay in course with the title , instead of circle around PSU .
Like … what's that ? :roll:
Burgerman wrote:Like this.
Tab: Presets
Sub Tab: General
Field: Lock Preset?
Special terms used with PL8 ?
Orded 2 refurbised units .
Started with the manual and user guild .
What next ?
Forgot to order the FUIM3 USB cable . Dam . :x
Postby Burgerman » 20 Dec 2016, 04:36
From the CCS - you will see.
Postby shirley_hkg » 21 Dec 2016, 08:09
:D Candidate of the charge lead .
6 large pins for the 2 charge current leads .
Each balance lead will take 2 pins .
Muli-pin to ensure enough surface contact . ;)
Will pick the 30a model . ;)
Postby Burgerman » 21 Dec 2016, 10:22
Those are interesting.
Postby expresso » 21 Dec 2016, 16:24
I like those - i would get the 40A model anyway - even if you dont charge at 40A -
you can put the power cables closer in the middle - making it easier to close it with the covers -
i dont understand what you mean - Put the balance wires on two Pins ?
there are enough pins to use one wire for each one - am i missing something ?
are those the same size DB25 ? do you have a link to those where i can buy some also - and the covers if you find some -
thanks - Shirley
Postby Burgerman » 21 Dec 2016, 16:54
Each balance wire, 2 pins... Half the resistance, better reliability.
Likewise, 2x 30A means 60A capable using 2 pins, or better reliability.
Postby steves1977uk » 21 Dec 2016, 17:49
This would be ideal for a BM3 style setup... https://world.taobao.com/item/193729395 ... mSite=main :)
Postby expresso » 21 Dec 2016, 18:31
Burgerman wrote:Each balance wire, 2 pins... Half the resistance, better reliability.
Ok - i still dont get it - haha - one balance wire - you will split it and connect it to two pins ?
how can you split one of those small balance wires ?
i cant picture it - you know i am a little slow right - :lol:
Postby Burgerman » 21 Dec 2016, 18:53
You don't need to. Just add some extra solder between the two pins. Or strip a bit of extra cable to reach the next pin...
Postby steves1977uk » 21 Dec 2016, 19:02
It must be the wine going to expresso's head :lol: or he's thinking about black women :mrgreen:
Postby expresso » 21 Dec 2016, 23:59
steves1977uk wrote:It must be the wine going to expresso's head :lol: or he's thinking about black women :mrgreen:
yeah - :) sounds good to me -
in real world use - would that really make a huge difference ? sounds like more work - and i dont get it - so you add more solder connecting two pins - i guess it could make it easier to solder the small wire on a larger surface of solder - you dont have to be so perfect -
then the balance wire is attached and its connected to two pins from the solder - ok and - thats it - thats going to do what ? you have to make sure to do the same to both ends male and female connector -
but its still just one wire its going thru - ?
if anyone does it - can you post a picture of the connector open to see how it would be done -
Postby expresso » 22 Dec 2016, 00:09
Burgerman wrote:You don't need to. Just add some extra solder between the two pins. Or strip a bit of extra cable to reach the next pin...
i see - spread the wire in two - long enough to reach both pins - but in the end its the same one wire its going thru -
i dont see how that can improve anything - but i am sure its something if you and shirley are talking about it - etc, - i just dont see it -
22awg wire - split in two - is still the same 22 awg wire in the end - and thats the balance wires - very little is going thru them anyway
now the power wires - maybe - if you can use 10 awg instead of 12awg - and if that fits to close the connector after - i can see connecting a larger 10awg to two larger pins
all i can say is the way i did it - following yours - works fine - its tight to make it fit - but i did it - and can do it again if i need it -
i like those connectors - seems like more room to work and i can put the power wires in the middle so dont have to bend them to make the cover fit etc,
i like to buy them to see them in person - but cant understand the link - how to order etc, - its not english -
Postby shirley_hkg » 22 Dec 2016, 03:03
Choices of combo connectors , and shell you can pick .
http://yangminpcc.m.taobao.com/?spm=a1z ... 2.0.0#list
Postby expresso » 22 Dec 2016, 03:49
thanks shirley - just cant figure it out - just a phone picture and everything in chinesse -
Postby expresso » 22 Dec 2016, 05:15
Burgerman wrote:Stupid blue connector that I cut off and replace with anderson...
you dont like that connector ? seems fine and easy to connect to the PSU with a EC5 charge cable - isnt that suppose to handle alot of current also - i think more than the XT90 ? or about the same -
i know you like the andersons - to keep; all your connectors the same for easy swap etc, - i like them also for the chairs etc, - besides being hard to remove -
EC 5 seems good and easy to remove at the same time - but then i dont use my PL 8 for so many different things like you do - mines stays connected to the PSU with the EC5 charge cable and sits there -
Postby shirley_hkg » 22 Dec 2016, 05:37
:D Anderson is superior in a way that , it does not have the MALE / FEMALE ..
Postby Burgerman » 22 Dec 2016, 09:46
Not only that.
I have them on my van, extension leads. Y leads, adapters. 12V and 24V setups on every chair, drills, solar systems on panels, and at the inverters, hobby stuff, 12/24v to 240v power inverters inverters, my bed, my mower, drill, on about 10 types of chargers, inside of powerchairs to connect batteries. And more. It means I have hundreds of options to power things, or charge things from solar, chair to chair, etc.
Power cut? No problem! I can run anything from 4 different chairs or my van. I can charge anything from anything. The van can power chargers, chairs, charge backup batteries. Etc. Everything fits! I can start my van with dead battery directly. Or charge it with a PL8 from my chair. Or the other way around. E.g. I powered the bed recently, when power went off from a powerchair at 12V. I also ran lights etc from my inverters, and if the power hadn't come back, could charge everything from van, solar, etc. So I can cope. Flexibility and options!
Postby shirley_hkg » 22 Dec 2016, 10:00
What is the estimated 12V input current , if I charge a 8S LiFePO4 pack @25A ?
Postby Burgerman » 22 Dec 2016, 10:25
3.600v x 8 x 25A = 720 Watts.
720 watts div by 12V = 60A. +a little because its about 90% efficient.
But in reality its about 3.35v most of the charge. And 12v is usually 13 to 14v... So you get about 27A charge at 60A input.
Postby steves1977uk » 22 Dec 2016, 16:10
I've left my PL8 with it's EC5 plug with no problems since I only use it to charge my chair's LiFe pack.
Postby expresso » 23 Dec 2016, 00:45
Using the new PL 8 i got exchanged - i can say that if the power supply tab is set at 50A - the most i can charge at with a 12V PSU is 20A
i stopped it and upped it to 60A in the PL 8 - restarted and the most i got it going at was 23A - not worth it - so i went back to 50A on the PL 8 and will use it at 15A charging for now -
my PSU is good for 75A -
i do notice this new PL 8 i got - always has a pop up message the first time i plug it in the PC - i think its this message - cant remember now - wine - tequila kicking in
i hear it making a clicking sound the charger at first before it starts to rev up - now i cant be sure if the first one does the same thing - i guess i am wary now since it was defective first time around -
not sure what to do think -
this may be the message it shows - or maybe a different once - have to wait to start over to see if its the same now - its charging now -
no error messages - just the first PL 8 dosnt show anything when i plug it in the PC - unlike this one that always has a message -
Postby expresso » 23 Dec 2016, 00:47
i think thats just a message because i stopped it and started again - if it wanted to save - add to the previous graphs -
i am not sure if thats the same message i get each time i started it - have to wait to try it again and see what it says
either way - no errors - but just that i never got it on the first PL 8 i got - -
Postby Burgerman » 23 Dec 2016, 00:48
Thats just the software asking if you want to save a graph...
Postby expresso » 23 Dec 2016, 01:09
yes - i dont think thats the same message i get when i first plug it in - have to do it again and post it back here -
when i am done charging - will do it - -
Postby shirley_hkg » 23 Dec 2016, 03:13
:( Received the PL8 , and find its balance port is small . Smaller than the connectors we usually have on the battery side .
Why not conform ! It's pointless . :cry:
Postby shirley_hkg » 23 Dec 2016, 03:29
And reversed pin order too !
Postby expresso » 23 Dec 2016, 03:51
this is the message i get everytime i use the new PL 8 i got -
i dont get this message with the first one i have -
what is it ?
Users browsing this forum: iansp and 141 guests
