In 1996 Curtis strengthened its leadership in motor controllers by creating an additional R&D center, Curtis Instruments AG, in Biberist, Switzerland
Change Log
** V4.1.0 (Build 529) **
General
- Minor bug fixes
Wheelchair controllers
- Added: Better communication support when running on slow PC
** V4.1.0 (Build 527) **
General
- Added: Installer now installs MTAPI for Windows 2000 and XP, too
- Added: Read/Write access level of a parameter is now contained
in program export file
- Improvement: Stop update thread during saving to file
- Bug fix: Check if focus can be set prior to setting it
- Bug fix: Removed memory leaks
- Added: Check if leaf nodes in the menu already exist. If yes,
append node id to the menu name to be able to distinguish the menu.
- Added: MRU support when loading file from second instance
(double click in Windows Explorer)
- Added: Do not show menu entries in menu tree when display as table view.
- Added: Now the filename is also added to MRU when loading by command line
- Bug fix: Table view parameters are now exported and printed correctly
- Bug fix: Adjust limits after cloning
- Added: Check if parameter is in valid range every time when user clicks on parameter
- Changed: Automatic check if parameter is outside valid range
only in developer edition anymore
- Items in default access level combobox in the settings dialog depends
now on the specific edition of the 1314
- Added new sorting of watchlist. Sort order is now the position in menu tree.
- Added online help file for all 5 languages
- Added showing all limiting parameter
- Added sorting of Error Histroy by timestamp if date code is the same in print out
- Added support for "OEMData" copy to install dir
- Added update thread feature to update changes of values
- Added: Show all dependencies and display the active one in a different color.
- Autosave programs are now saved in 'my documents' area of windows.
Vista does not allow to write in program files area.
- Bug fix: Change color of parameter tree if value changed
- Bug fix: If no com port is present on the PC then no error occurs anymore
- Show IME hardware selection only when IME driver is installed
- Bug fix: Now the height of dependency list labels is calculated correctly.
- Bug fix: Only start updateThread when object exist (e.g. offline system)
- Bug fix: Removed exception when no COM port exists in the system
- Bug fix: Set OEMData source files as optional
- Bug fix: Set visible of action items
- Changed 'device software' path to my doc directory, due to writing
rights limitation under Windows Vista
- Changed path for OEMData to be Vista compatible
- Minor bug fixes
- Added: Support for Binary Menu Display Options (MDO)
- Added: When setting default value, it's checked if within min/max range
- Bug fix: Fault entry structure had wrong data type
- Bug fix: Due to bus overload en error #2 occurred on HC after some time
- Added: System properties are now imported when importing master device
- Added: Added for battery statistic view (not supported by all Powerbase)
- Added: Support of data sections for MC-2 system
- Changed: When parameter value is out of range with MCP, then it's set
it to its default.
- Changed: Incremented Firmware update timeout to support 8MB flash
- Changed: Refresh timing improvement when switching off system
- Bug fix: Works now correctly with I+ME PCI card
- Bug fix: When reading from cache file, the device number in output
items was not set to actual device number.
- Bug fix: Reset "ShowAllParameter" state when connecting to a system
- Bug fix: Only clone data sections which are present in the destination system.
- Bug fix: "Devicenumber" was get with wrong index.
- Added some checks to prevent impossible configurations in AAM configuration dialog
- Added some waiting time after saving config data to allow devices to save it into eeprom.
- Added waiting time to prevent error #2 on device
- Bug fix: Check for already used actuators now works correctly
- Bug fix: Do not display lastest SW version when connected to a MC-2 system
- Bug fix: Save the data length before sending the semaphore token. The length
member in SDO struct will be initialized to 0 by waiting task and therefore a
wrong value was returned as length.
- Changed images of N.O./N.C. MIO
- Changed menu priority of root menu for MC-2. Device config is now at
the same position as e50
- Check if data are refreshed in a online system when retrieving config data
- New texts
Material Handling controllers
- Bug fix: Cloning from .PAR files now works correctly
- Bug fix: When multi configuration is present, now values of all configurations
are updated prior to saving a file
- Bug fix: Advanced cloning is not allowed for SERIAL protocol
- Bug fix: Now COM ports > COM9 can be used.
- Added additional infos to create cache file name with S protocol
- Added exponent normalization when using dependency parameters
- Added improvements for S protocol controller support
- Bug fix: Added exponent normalization when using dependency parameters.
- Bug fix: Dependencies are now working correctly with S protocol
- Bug fix: Dependencies for ES/S are now handled correct
- Bug fix: Reset dependencies in case it already exists from a
previous parsing (e.g. P or Q command)
- Bug fix: S protocol uses now AltAddress as ID - Added support for write protection with S protocol
woodygb wrote:CanFox is around 110 Euro's .. plus p&p and tax probably!
woodygb wrote:TOTAL rip off ..I was quoted £125 ( trade ) direct from Curtis
viewtopic.php?f=2&t=1256&start=20&st=0&sk=t&sd=a#p16423
Seajays wrote:I ordered one of these.
http://www.ebay.com/itm/330721908764?ss ... 062wt_1141
Users browsing this forum: LROBBINS, shirley_hkg and 64 guests
