assuming bulk charge rate is in proportion to the C of the battery .![]()
I used it to charge a battery through hyperion( as I was a little worried to use my new PL8) but the current was about 3 amps as the battery was already charged. One thing I noticed, the menu#2 has to be kept at 60V.
@martin007 , do you want me to have it set up for your MK, and how would you like it programmed ?
once the 3 stage is enabled.Easy after the first day ofonce the 3 stage is enabled.
Burgerman wrote:Then its going to be interesting.
martin007 wrote:With 12A I will not sleep easy.
Burgerman wrote:I wouldnt mind another one ready to go with mod already installed and tested. And another fancy case. All same as before.
Next time you are ready to order some. No hurry.
Users browsing this forum: Bing [Bot], shirley_hkg and 62 guests
