Postby Burgerman » 25 Oct 2017, 01:35
You will lose around 15% range at full speed, and about 40% more current (taking quite large chunks at high amps) accelerating at low speeds and while hill or slope climbing.
On my PC your photo is inverted!
>>> Not me. I'm in USA.
Postby shirley_hkg » 25 Oct 2017, 03:17
drunk2 Found ONE bad cell , amongst 400 , bought and set aside last year . hanged
Voltage 3.317V still . cheers
Postby Burgerman » 25 Oct 2017, 03:21
Looks like it is deseased! hanged :ambulance
Did you test capacity? At say half C rate to 2.5V you should get full capacity.
Postby snaker » 25 Oct 2017, 04:04
I just finished discharging the pack from full to empty (2.90V). The total Ah taken out is 47+91.7 = 138.7Ah. Cell 6 appears weaker than the rest. Can I do anything to improve its voltage?
After discharging 0-47Ah
After discharging 47-138.7Ah
Cell volts at the end
Postby shirley_hkg » 25 Oct 2017, 04:41
I'd swap ONE cell of group 6 & 4 , with that of the 7 & 1 respectively . cheers
Existing state is fine already . goodpost
Postby expresso » 25 Oct 2017, 04:43
I would think that since you have 150ah - thats large - you may never get low enough in a day to be too concerned - unless Cell 6 gets worse - Cell 2 and 3 are the next which are in the 3v area after Cell 6 -
i have 135ah now - and i havnt been able to get past 44 Miles at the most so far - used up about 100ah - leaving 35ah still - maybe BM may have a solution to condition it a bit - maybe a tweak with the charging preset to help it a bit -
Postby expresso » 25 Oct 2017, 04:45
shirley_hkg wrote: I'd swap ONE cell of group 6 & 4 , with that of the 7 & 1 respectively . cheers
i see - that makes good sense - would even it out and discharge more evenly - nice - pain that you have to take it apart but with those big cells - its easier than using the Headways
Postby snaker » 25 Oct 2017, 09:07
Yes, reassembling cells is truly a pain. If the cell 6 is not a big problem, I will leave it alone.
Postby Burgerman » 25 Oct 2017, 09:19
Would definitely watch 6. Theres one slightly bad cell there.
Postby dEknowmight » 25 Oct 2017, 15:44
Odd about that photo.. makes Australia sounds funny now.
dEknowmight
Postby Burgerman » 25 Oct 2017, 17:30
Does anyone else see it upside down? :o
Postby expresso » 25 Oct 2017, 17:37
Burgerman wrote:Does anyone else see it upside down? :o
yes - i see it - its down under - upside down
Postby Gnomatic » 25 Oct 2017, 17:39
That pic shows as upside down for me as well, in Chrome, Firefox, and IE. So its not a browser thing.
Postby Burgerman » 25 Oct 2017, 17:59
Must be because australia. :fencing
Postby rustyjames » 25 Oct 2017, 22:42
It's upside down for me too, but it wasn't yesterday.
rustyjames
Postby Gnomatic » 25 Oct 2017, 23:33
Dang. These can be had for ~$13/unit now.
https://item.taobao.com/item.htm?spm=a2 ... =14#detail
Wouldn't mind ordering about 20 cells(using the 16 strongest) and basically make a clone of snaker's pack. At that price its seems worth it to take a flyer on these. Winter project for second chair. But getting them shipped to the US is banghead banghead banghead banghead .
Postby expresso » 25 Oct 2017, 23:51
that would be great price wise - and 150ah would be very nice to have on hand - inside a chair - thats amazing -
Postby Burgerman » 26 Oct 2017, 00:25
Remember that the casings are all 3.3v apart. And he got 135Ah out. And a faulty looking cell. So not ideal.
Postby Gnomatic » 26 Oct 2017, 00:39
That's why I'd get 20, a 25% bad/weak cell allowance. Theres room for ample insulation in between each cell in both my chairs. So maybe not ideal, but at that price, hard to complain.
Postby Burgerman » 26 Oct 2017, 00:45
How can that be possible :problem:
If I download it, save to desktop it displays the right way up in paint shop pro! And presumably photoshop. Try it! :cussing czy
Postby Burgerman » 26 Oct 2017, 00:50
And uploaded it again. In windows its correct. In photoshop its correct. When uploaded its upside down to me here. What gives. :geek: :cussing
Postby snaker » 26 Oct 2017, 01:44
Gnomatic wrote:That's why I'd get 20, a 25% bad/weak cell allowance. Theres room for ample insulation in between each cell in both my chairs. So maybe not ideal, but at that price, hard to complain.
These cells are not that bad. You do not need 4 spare cells but because they are so cheap, 4 spare cells are not a bad idea. I note that I left their metal cases which are also positive poles touch the ground in 2 weeks. They should be all dead but they survived (although with weak health :cussing ). I would not have faced any problem if they had been insulated and stored by the right way.
My worried thing is the naked metal case. It is so dangerous. It would be better if you could find other cells with plastic cases for the same or a little higher price. Shirley might help :roll:
Postby rustyjames » 26 Oct 2017, 01:59
I have no idea, all I can tell you is that when I first saw it it wasn't upside down drunk2
rustyjames
Postby snaker » 26 Oct 2017, 02:07
The pack's charging graphs do not look perfect but seem Ok. I see in the IR graph, cell 6's IR is lowest. In theory, it should be stronger than other. Why is it weaker in reality?
Postby expresso » 26 Oct 2017, 02:07
if you click on the picture - it shows up correct - its upside down just on here
Postby rustyjames » 26 Oct 2017, 02:16
Forgot to mention, cool Dog!
rustyjames
Postby dEknowmight » 26 Oct 2017, 16:14
The dog is Julie. She loves riding on my lap, and even demands to sit there while I work some days.
I googled a bit on the image and best I can see is that the orientation tags are not honored. iPhone has weird issue sometimes with pics going sideways.. they have to be edited to correct them. Maybe this is related.
dEknowmight
Postby Burgerman » 26 Oct 2017, 16:26
So another reason not to use betamax. :fencing
Postby snaker » 27 Oct 2017, 04:06
The pack is ready for the first ride test.
Postby Burgerman » 27 Oct 2017, 10:43
Dont come back till its down to 3Vper cell and take food, drink, clothes, and a calender toilet roll :biker toiletpush . You might be able to leave the country. :biker :ak47
Users browsing this forum: emilevirus, shirley_hkg, tettralytic and 90 guests
