Postby Burgerman » 03 Apr 2016, 22:24
Opps my mistake - i went too much - its too wide - it will be one roll down the sides and then double rolls in the middle - should have been 3 double rolls in the middle - and one roll each side - making 8 rolls -
Rolls? https://www.google.co.uk/search?q=rolls ... =610&dpr=2
Postby Scollard » 03 Apr 2016, 22:28
expresso wrote:this is how i will make the TOP - its upside down - as if it were the bottom - the top would be flipped over with the feet facing up -
That looks correct, but you have an extra row of orange blocks. You have it 10 wide but you only need 8 rows. Remove one row of 6 blocks.
The weight of a 6x8 cell pack will be approximately the weight of a single group 27 lead battery. Tiny bit heaver that a group 24.
Scollard
Postby expresso » 03 Apr 2016, 22:29
i keep making those mistakes - not the greatest speller here - Rows - i mean -
and in two parts - that nice - but the way i am building it - it has to be one big pack - i wont be lifting it thats for sure - two parts or 3 - - and not much heavier than just ONE LEAD -
two people - one on each end should be fine - - and i hope to not have to remove this once its all done and in the chair - unlike the ADD ON - i did that over 4 times !!! - now its done - and this i want to be done the first time - not looking to redo this 4 times
Postby expresso » 03 Apr 2016, 22:30
yes making me hungry now :) and i just ate -
Postby Scollard » 03 Apr 2016, 22:37
BM has put together a lot more of these packs. how do you recommend putting the orange blocks together.
Would you make a row of 6 horizontal blocks, then make a 2nd row of 6, then put the two rows together?
Or.
Make a row of 6 horizontal blocks, then make the 2nd row by adding them 1 at a time to the initial row?
Or would you make the top connector blocks directly on top of the cells that are already placed in the bottom one at a time. I know I had a hell of a time putting on my 4x7 top block and I wondered if it would have been better to build it one at a time directly on top the the cells.
Scollard
Postby expresso » 03 Apr 2016, 22:49
it would have been two packs - just like LEAD - 2 12 volts pack and connected - but i didnt feel it was going to work out that way - just very tight and i need room to work with the wires etc, - and with my divider - i tested it first with the 12ah cells - 72 of them - i didnt like how it was going to end up - the orange blocks were scrapping the underside of my divider - it was just tight and i didnt want to go down that road - it was stressing me out to figure out how to force the divider up higher - i just cant - i have very little wiggle room to do that - which i will do now - but that still wasnt enough for me to feel good about making it with the 12ah cells -
and then Scollard jumped in and offered me another way that i wasnt thinking of - once i though about it this other way - i found this way to be 100% for sure i can make it happen - even if i only end up with 90ah in the end - i know thats for sure after doing the math and all the cells fit in the original battery tray - thats great - thats what i wanted - simple - take out LEAD - drop this in - same tray -
i guess between Shirley and Scollard - they both played a major role here - you BM of course always helping -
Shirley got me started because he got me the BMS which made me feel good since i didnt know nothing at all - not that i do now - :mrgreen: but i wasnt going to go all in - so i went with the BMS - since then i decided to go all in and then didnt feel good about the 72 Cells 12ah -
then Scollard jumped in and that again gave me an extra boost of confidence and i started to check those figures out - that was and is the best easiest way to get this done with out having to do any thing major to the chair itself -
90ah pack - would have to do nothing at all - 105ah - i have to raise that divider up as much as i can and test it first -
you BM - always along the way tried to help me do things - even when i didnt listen :) and went left instead of right - everything was so new and strange to me - and you spoke to me as if i knew what you were talking about - haha -
i didnt - i didnt know what a XT connector is - or this and that etc, -
now i know - and i would be using the XT90 for this chair also - for the charge cables and the extra cable for ADD ON - if i want to add one later - i am just making the cable for it and connecting it to the pack - but may not be used -
the XT90 connector i tested it can be snaked under the frame and into the battery box from the top rear - so it should be out of sight - we see when i get there if it really works out that way -
i cant sleep without thinking of ways to do things and get around the bumps now - alot of times thats when i get the solution when i am in bed resting - it comes to me - or at least another way to tackle it and see -
Postby Burgerman » 03 Apr 2016, 22:51
Thats impossible without damage and problems.
I have done about 6 of these and a couple of small hobby ones.
You need to make a full row, longways, and add it to the next full row. And over and over.
To make a side you do this first. Make as many full lines as you will need:
8
8
8
8
8
8
8
8
Then add another FULL row of these AT ONE TIME. Not one by one. Start at one end, and slot together just 2mm at a time and work along. Then on a flat desk gently tap down till its flat. If you do it right yu can do it with only fingers 90 percent of the time.
8 8
8 8
8 8
8 8
8 8
8 8
8 8
8 8
And again...
8 8 8
8 8 8
8 8 8
8 8 8
8 8 8
8 8 8
8 8 8
8 8 8
Postby expresso » 03 Apr 2016, 22:57
i was having a hard time doing it that way one full row at a time - i did two rows already - but one block at a time snapped it down all the way before adding another block
i will try it again your way with one long row - i cant trust this to be done by my workers - i can get it started at least and then they help me bang them down -
there is no gently tapping down here - too gentle it dosnt move at all - its more like banging them down here - as careful as can be but it requires more than a Tap - at least mines do - i may try a shot of silicone spray- just a mist and see how that works -
will leave it for tomorrow now -
Postby Scollard » 03 Apr 2016, 23:05
Ok Expresso, there you have it. Put 4 blocks together end-to-end so that you have 8 wide. Make an identical 2nd row. Then add the 2nd row to the first. Repeat until you have 6 rows. This will be the bottom.
For the top you only put 3 blocks together so you are 6 wide. Do this 6 times until you have a 6x6, then add the 3 blocks on either end to make the single row.
Scollard
Postby expresso » 03 Apr 2016, 23:09
Scollard wrote:Ok Expresso, there you have it. Put 4 blocks together end-to-end so that you have 8 wide. Make an identical 2nd row. Then add the 2nd row to the first. Repeat until you have 6 rows. This will be the bottom.
yes - this is the same layout as before the way you told me right ? like the pictures i sent - - its just a way to try to connect them - but the lay out is the same ?
just like the ADD ON -
Postby expresso » 03 Apr 2016, 23:12
another question - Once i remove the LEAD from my chair - i will leave it empty with nothing in there till i am done with this pack - is it OK To leave my chair with nothing connected to it - no batteries at all - for the time till i get the pack done -
lets say its stills empty for a month or two months - any problems with that ? once i connect battery power again - it should be just fine - work the same etc, programming ? all functions -
Postby Scollard » 03 Apr 2016, 23:17
Yes, just like the add-on.
Do you have a soft-blow hammer or a rubber mallet?
I used something like this to knock my blocks together.
http://www.amazon.com/TEKTON-30812-Doub ... 0NYN313_tt
Not an actually hammer.
Scollard
Postby expresso » 04 Apr 2016, 00:00
yes i got a 3 hammer kit - for 10 dollars - has 3 sizes - rubber ends - i have used it - but sometimes i find the steel hammer - i have a smaller one - with a towel over the area - works because of the weight -
i will continue that tomorrow - i have 2 Rows connected - the bottom side i am doing first - i am going to give it a mist spray of silicone also - just to see if that helps
also - can i use the marine grade rings i have already with heatshrink on it for the wires to connect the top 8 Cells - ?
or should i use the Copper lugs i have - but they are 8 AWG - and i can use it - but with 12 AWG wire - its a big small - or i can double the wire end and use the copper lug
either one is ok ?
Postby Scollard » 04 Apr 2016, 00:10
The ring terminals for the balance wires are going to be too small. Or did you get some for 10-12 AWG wire? If not, you should get some marine terminals for the 10-12 AWG wire.
Scollard
Postby expresso » 04 Apr 2016, 00:16
i have those for the balance wires - - the wires for the 8 Cells on top - if i end up using 12 AWG wire - i have more than enough of these
but i have to thicken the wire http://www.amazon.com/Install-Bay-Coppe ... ge_o04_s00
and these - for 12 - 10 awg also - http://www.amazon.com/Ring-Terminal-Mar ... ge_o07_s00
either one of these should be fine ?
Postby expresso » 04 Apr 2016, 00:50
Scollard wrote:The ring terminals for the balance wires are going to be too small. Or did you get some for 10-12 AWG wire? If not, you should get some marine terminals for the 10-12 AWG wire.
i have 12 AWG wire - enough to make the cables for the top 8 Cells - i have some 10 AWG also -
the lugs i have are for 8 AWG really - but i can make it work if i have to -
i also have the marine rings for all the balance wires - and also for the 10 and 12 AWG wires -
if i used the Marine rings - i can just crimp the wire and heatshrink it -
if i have to use the copper lugs for 8 AWG then i have to crimp and solder - -
if its ok to use the Marine rings - i may use those instead
Postby Scollard » 04 Apr 2016, 00:56
Yes, just use the marine rings for the 10-12 AWG wires. It will work just fine. You will need 4 long ones to run from the bottom of the pack and 5 short ones for the top. That means you will need a minimum of 18 ring terminals to add the 7th row on top.
Scollard
Postby expresso » 04 Apr 2016, 00:59
oh - i didnt think that many wires from the top cells only -
ok i will check - i have to get more i think - will get the marine kind with heatshrink on it already - for 10 to 12 awg wire -
i have about 10 feet red and 10 black of 12 awg wire -
sorry 18 rings - just 9 wires :)
Postby expresso » 05 Apr 2016, 18:26
Ok i finally got the bottom made for the 90ah / 105ah pack -
I tried doing it your way BM - connect 4 blocks making one long row - and then adding to it - that was harder for me - and when i got most started - the very end one i couldnt get started - - i figured out what works for me best is this way
which may seem harder at first but it works - easier for me to handle one block at a time - rather than a whole row - the picture shows how i found it to work easier - the way i add the one block makes a difference also
i get one end started just a bit so it holds it - the other end is lifted up - then i use the hammer to tap it down and it grabs and works perfect that way - i then bang it down all the way - and do the next one - it may sound harder or more work for you - but for me - alot better - i still dont like making them - mines arrived different colors also - all orange some lighter and darker etc, - i figure its not the same batch when made - as long as it works i am good -
Postby expresso » 05 Apr 2016, 18:36
i arranged all the cells in correct order - i actually forget to test fit the orange blocks in the tray first before adding the cells - it fits - but wanted to see if any room down the sides for wiring - i really dont think there is - but when i do the top part of blocks - i can use that to check it in the tray - i checked it when i have 5 rows all snapped in place and just one row left and it fits like a glove - which is a bump in the road when i get there if doing the 105ah pack - if doing 90ah - its fine -
i got a rough measure of the total size as a 105ah - i get about 9 1/2 inches high - i will double check that once i get the top row in place - blocks on and then remeasure it - i feel if i can manage to raise my divider up a bit as i plan to try doing next week or once i get my friend to help me with that - i would have the pack connected by then and can Fit Test it - if it fits with 105ah - then i have to work on that Tray - maybe cut one side of the Lip to make room for the wiring -
Postby Burgerman » 05 Apr 2016, 18:40
I dont see how that can fit.
Postby expresso » 05 Apr 2016, 18:42
extra row on top if i can make it fit - i am not sure where i wire the top row to - when i am done making the 90ah pack - i will post a pic - Scollard - if you can use the pic i will post when done and draw lines to mark exactly where i would connect the top 8 cells to the 90ah pack - i want to be safe and do it correctly when connecting - i already know what can happen if connected wrong -
this is assuming 105ah is going to fit and i feel good about how it fits etc, - if not - then 90ah - and leave the tray alone -
Postby expresso » 05 Apr 2016, 18:51
Lithium ion batteries, by definition, are energy storage systems. As such, the energy in the systems can be unexpectedly released thereby presenting safety issues (e.g., hoverboards). Now imagine an energy storage system that is 200 times the capacity of a hoverboard in applications like data centers, electric buses, marine workboats, or critical medical equipment. The results could be disastrous.
The Larger the Energy Storage System, the Safer the Battery needs to be.
Different lithium ion technologies exhibit different safety profiles. The challenge of mitigating safety risks in any application is paramount and rests with choosing the right lithium ion technology for the application.
Taking Battery Safety Seriously
The intrinsically safe profile of the lithium magnesium iron phosphate (LiFeMgPO4) cathode material as the core of Valence batteries makes for a technologically advanced solution for lithium battery applications in today's safety conscious market. For over a decade, Valence has been safely supplying over 100,000 battery packs for Segway's Personal Transporter. The following performance factors support choosing Valence’s LiFeMgPO4 technology over other mixed oxides.
Valence batteries provide:
Intrinsic safety profile of cathode material
Quality production, from cells to modules, to full packs
Multi-level safety features, including an integrated Battery Management System (BMS)
Modular capabilities for flexibility of design as well as redundancy
Scalability while retaining safety
Valence is able to design solutions for a wide variety of markets:
interesting how i just got this Email right when in am building my pack - trying to scare me off you think ? :D
www.valence.com sales@valence.com
Postby expresso » 05 Apr 2016, 18:53
Burgerman wrote:I dont see how that can fit.
what do you mean ? you mean the 105ah pack or the 90ah ?
Postby Burgerman » 05 Apr 2016, 19:05
I mean the one in the pics...
Postby expresso » 05 Apr 2016, 19:07
the 90ah pack fits perfect - in the battery tray - that way is the closest to plug and play as you can get i think - - i will start the top blocks and add them - connect the Cells on top - then wait for a friend to flip it over for me - connect the bottom cells - wait again to flip it back and in the tray - to test fit it - once i get the chair ready with the divided etc, -
Postby expresso » 05 Apr 2016, 19:09
Burgerman wrote:I mean the one in the pics...
which pics - which cells are you referring too ? top 8 Cells for extra Row on top of the 90ah pack - ?
Postby Burgerman » 05 Apr 2016, 19:14
Dunno. How many are you making now?
Postby expresso » 05 Apr 2016, 19:19
ok these are 15ah cells - the perfect fit in the tray one big pack is 90ah - that will fit no problem - the extra 8 cells on top - if it fits in my chair space - then its 105ah - i am leaving that option open to try -
will have to work on my chair divider to raise it up a bit - i have an idea for it - i have to do that first - once i get the divider up most i can - then i will test fit the 90ah pack in the chair and slide the extra 8 on top - just to see if it fits in the chair before deciding which way to proceed -
if the 105ah pack fits - if i am comfortable how it fits - etc, - i can then try to add the top 8 Cells to make it 105ah - if i dont like how it fits in the chair - or it dosnt fit - or what ever - i go back to just the Tray 90ah - pack - thats 100% fit with ease - and room to work - which i like -
Postby Scollard » 05 Apr 2016, 19:54
Looking good. Now you just need to get the top on. That will probably be the most difficult.
I also put my blocks together either 1 or 2 at a time. I found that easier than an entire row.
When you put the battery in the chair will the negative row or the positive row be at the back of the chair?
Scollard
Users browsing this forum: LROBBINS and 440 guests
