shirley_hkg wrote: I will put one or two sheets of cardboard between BMS and cells as insulation .
ok i can do that and put the rubber sheet also over the cardboard also - - have to wait till i get everything else i need now -
thanks -
shirley_hkg wrote: It's safe enough your way now.
Put a cardboard or two between bms and battery and you are safe to wrap them up for easy handling. Then go and see how you gonna carry it
expresso wrote:seems simple enough but i feel like when i reach a point = more things pop up that i have to do - i have to find that bulb on amazon or ebay first - wrap a wire to both those ends on the bulb - then stick that ends in the sb50 - a certain way -
pos to pos or dosnt matter - i am not comfortable when i dont know what i am doing for sure - dont want to blow this up after i get done -
i cant just plug it in my chair and use the chair - but then i would have to charge the chair anyway - i believe Shirley said it was fine to leave it connected to the chair - charge as normal and can leave it on float as i normally do
is that not the case ?
http://www.amazon.com/gp/product/B00IKL ... l_huc_item
i need to add a few more items before i can place an order for free shipping etc, - would this bulb work ?
expresso wrote:Ok
hows this ?
http://www.amazon.com/gp/product/B000QD ... _mrai_2_dp
http://www.amazon.com/gp/product/B0074I ... l_huc_item
let me know if any of these are good - so i can place an order - i wish i new i just placed an order yesterday -
is there anything you can think of that i may need to cover this or wrap the whole thing etc, - i like to place an order for everything else i may need to get this finished and covered protected safely -
i guess i have to wait now to get all the items before i finish it up ? No use connecting the BMS now till i can wrap it safely
shirley_hkg wrote: Cut an opening on wrap for the plug to get in.
The LEDs should face outside. It's on the opposite side of the aluminium plate.
BTW, please seek MY advice first , before stepping further .
Don't get distracted.
i would have to leave the bottom and top roll of cells exposed to balance charge it - so wont pack it till the end - i wont have to rebalance charge again each cell group after the first time ?
Users browsing this forum: jehan and 404 guests
