Burgerman wrote:The valve holes are round. Once you line the rear and front halves up to the correct position.
Burgerman wrote:That seat dump is adjustable in 3 far too wide positions. And depending on seating/options in 2 different ways where it connects to the frame. Basically 2 bolts. So I drilled 2 new holes in the correct place...
Burgerman wrote: And with programming you can set that tilt inhibit to any speed. Including full... Or move the microswitch to a slightly different position so the turtle appears later.
Burgerman wrote: Never plastic wrapped! Cant stand n****r music... Its 3 very small parts. Any car body shop will do them black, plus laquer for 30tokens! The stickers are available from sunrise.
Burgerman wrote:That pic shows r-net power module. The seating/lighting one is in front behind a plastic easy to remove cover. And smaller.
scooterman wrote:]id I pull the short straw as far as controllers go? I’m thinking what with a programming lead hard to source?
Burgerman wrote:Theres one way. An OEM dongle. Not cheap. Or find a user with one and a train ticket. And a day to fine tune everything. Or https://powersoccershop.com/pcprogrammer.aspx About 300 uk pounds. Then you will need to fight the customs as they will charge vat...
I plan to do the same. Well as near as I can manageBurgerman wrote:The image of the control pod above was still low. Its now 20mm higher on a alloy spacer, and the centreline of the controller is in line with the inside edge of the arm.
Burgerman wrote:Note that there are now 4x 5mm thick spacers, sat one on top of the other. Under the joystick.
When I first went up the road in the chair for a test run I was weaving side to side because I kept on over-correcting.
Burgerman wrote:You cant balls it up.When I first went up the road in the chair for a test run I was weaving side to side because I kept on over-correcting.
Thats because of the "programming"...
Scooterman wrote:People who don't know of WD (or don't care) must struggle on in ignorance for years.
foghornleghorn wrote:Scooterman wrote:People who don't know of WD (or don't care) must struggle on in ignorance for years.
They struggle, or they just give up and sit in an armchair all day. It's the reason there are so many second hand wheelchairs for sale that say 'used twice' and look like that is genuinely the truth.
Burgerman wrote:1) Odds on squeezing 3.00 x 4 into 9" forks
DUNNO... The tyres I fitted are nominally 3.00 x 4 but measure a little less like 9.5. So get some the same and you should be OK. Black tyres the size you have are hard to find.
Burgerman wrote: 2) Arse sitting high - is it a problem?
SHOULD be no problem. If it is, fit spacer and longer bolt.
: Burgerman wrote: The 90A power module offers less torque than the 120A one. Which is why I paid extra. But you are light? And with seat moved back, it should work reasonably well. If not keep watching ebay... It may not like steep ramps, or zero turning at times.
Burgerman wrote: Having got used to looking at my 120 tyres/rims those stock wheels look stupidly small!
Burgerman wrote:Yes, 27.5 wide...![]()
On one of your pics theres a microswitch visible behind the seat. That can be adjusted so you dont see the turtle as soon. And so can tilt back more. But better achieved by altering the seat base angle.
Burgerman wrote:I THINK that that is the one. I may be wrong. But watch it as the seat tilts to see if that one is the correct one. If so some minor mechanical change/adjustment will stop it acting so soon. On the other hand, mine will be disabled in software completely when I get around to doing it. The reson its there is because if you tilt, esp when high up, or on anything but level ground the chair may tip over backwards as you move forwards. Made worse by moving the seat back. So recline, and tilt can be dangerous! Especially if seat is raised. But its common sense to me so I use my brain.
Users browsing this forum: emilevirus and 99 guests
