Postby terry2 » 16 Mar 2019, 17:33
Burgerman wrote:Get it fitted. Still check cell connections on 3 4 5 but its good enough.
I will re-check the connections on 3-4-5.
I have got to take the centre foot stand off to get to the chairs cables.
I have bought a fuse hold that will be fitted.
Then a friend is going to put them in the chair as I can't move them :oops:
Thanks to all for your help.
Can't wait till testing time :D
Postby expresso » 16 Mar 2019, 17:35
Very good Terry - you will be very happy with the range - summer is here :clap: :thumbup:
Postby steves1977uk » 16 Mar 2019, 17:53
I use one of these 125A Littel fuses... https://www.littelfuse.com/products/fus ... eg125.aspx Hasn't blown since my pack was built in late 2014.
Postby Burgerman » 16 Mar 2019, 19:05
Bit big physically though. The midi fuses are way smaller.
Holder.
Fuse.
https://www.ebay.co.uk/itm/MIDI-STRIP-L ... zCXWSQFKKw
Get the 100 or 125A
And a couple of ring terminals for 5 or 6mm bolt.
Postby terry2 » 16 Mar 2019, 21:30
steves1977uk wrote:I use one of these 125A Littel fuses... https://www.littelfuse.com/products/fus ... eg125.aspx Hasn't blown since my pack was built in late 2014.
Thanks dude.
I did get the one BM has posted about.
Burgerman wrote:Bit big physically though. The midi fuses are way smaller.
Holder.
Fuse.
Get the 100 or 125A
I have got the holder coming.
May I ask a silly thing? Are these cells supposed to lose charge over night?
Maybe 2-4%
Postby Burgerman » 16 Mar 2019, 21:52
How are you determining a loss of charge?
The VOLTS will fall, to the natural 3.3xx level in time. They are still full.
Postby expresso » 16 Mar 2019, 21:56
Terry - they will fall to there normal voltage but no worries - thats how they are - i charge night before full - go to sleep and use the chair next day - no need to recharge again before you go out - you have a Ton of Range there
Postby Burgerman » 16 Mar 2019, 22:16
What is it to fit again? Speed?
Postby terry2 » 17 Mar 2019, 08:19
expresso wrote:Very good Terry - you will be very happy with the range - summer is here :clap: :thumbup:
Sorry I missed your post. Thanks dude.
Burgerman wrote:How are you determining a loss of charge?
Thank you.
Now I understand.
Burgerman wrote:What is it to fit again? Speed?
Puma 40. I travel 6 miles on the road @6-8 mph
My 2 MK gels need a recharge after I get to the hospital :(
Postby Burgerman » 17 Mar 2019, 09:05
These wont. You should get four times the range.
Dit you order a small cell alarm/fuel gauge thingy?
https://www.banggood.com/ISDT-BattGo-BG ... rehouse=CN These are OK. I got one. You can manage fine without. Take 10 days to turn up.
Postby terry2 » 17 Mar 2019, 09:57
Burgerman wrote:These wont. You should get four times the range.
So about 24 miles at 6 mph woooooooo :D
Yes I have got that monitor.
I've set the alarm to go off at 3.2V as I find my monitor about 0.100 out.
I am going to redo the connectors on 3-4-5 to try and get them all the same balance.
Postby Burgerman » 17 Mar 2019, 10:56
What are you checking it with? Mine is pretty close to a calibrated 600 quid fluke!
I would expect 2x that. But dont test that yet till you are using tht meter and watching to see which cell drops down first. It will happen quite suddenly. At which point you stop or cause damage.
Postby terry2 » 17 Mar 2019, 11:56
Burgerman wrote:What are you checking it with? Mine is pretty close to a calibrated 600 quid fluke!
I compared it to what the PL8 software was showing.
Postby Scooterman » 17 Mar 2019, 12:12
When out and about do we check the voltage on load or off load? If off load do the cells have to rest for X mins before checking voltage?
Postby Burgerman » 17 Mar 2019, 12:21
Both.
Not below 3V off load, half a minute is long enough. That tells you state of charge.
2.5V on load. That varies WITH load. So it will drop a lot as you climb a ramp or accelerate from a standstill hard. Worse as it becomes more discharged.
Postby Scooterman » 17 Mar 2019, 13:01
Thank you BM, I've made a note of the values :thumbup:
Postby shirley_hkg » 18 Mar 2019, 03:11
steves1977uk wrote:Are you using an external XLR socket directly connected to the batteries Shirley? I'd be very surprised if you're pushing 20A through the pod's XLR port! :shock:
No gimmick . Use just one XLR. Tried 22.25A max. See page 129, 133.
Switched to PL8, and removed BMS became obsolete . We put a D-sub to it so we can charge our LiFePO4 in a protected way with dump charger in the absence of a PL8 , when we are away from home , eg travelling .
They are of over-voltage cut-off @3.65V
Page 92: https://www.wheelchairdriver.com/board/ ... start=2730
Postby terry2 » 19 Mar 2019, 10:49
I'm now just waiting for a friend to bring me his wheel ramps to me.
Then I can start on wiring the chair :)
Postby Burgerman » 19 Mar 2019, 21:54
Yet you were terrified and thought it was all beyond you 2 weeks ago. cheers
Postby terry2 » 20 Mar 2019, 09:34
Burgerman wrote:Yet you were terrified and thought it was all beyond you 2 weeks ago. cheers
My bill for my monthly man nappies would not agree :oops: :lol:
Postby Burgerman » 20 Mar 2019, 10:22
Wiring the chair is easy. Just make 1 lead with an anderson on it with a 125A fuse and 10sqmm cables.
Did you make a charge connector using the 40A SubD connector?
Postby terry2 » 20 Mar 2019, 17:34
Well the cells are in. But it's not a pretty sight :(
I checked it with the cell monitor and it's alive :D
I was on my own and it took my from about 11am till now to fit the cells and wires.
But I never knew that the battery box on the Puma only has two slots for wires.
Both are on the wrong end for me.
So for now I have just tucked the earth and positive wires in the back till I can find a better way.
I have to put foam on both sides of the cells to stop them moving.
Then Put the centre foot stand back on. And wait till my mate comes back tomorrow to put the chair on the ground.
The Puma has very little space to work in. I could just about put a mini ratchet in to tighten the nuts.
I will charge it in the morning once I have finished putting the chair back together.
And report back then.
Postby terry2 » 20 Mar 2019, 17:35
Burgerman wrote:Wiring the chair is easy. Just make 1 lead with an anderson on it with a 125A fuse and 10sqmm cables.
That is really nice. But I can't fine solder anymore. So I have 2 leads.
Postby Scooterman » 20 Mar 2019, 19:37
I managed both packs insulated. I’m reasonably pleased with how they’ve turned out. Shirley’s parcel arrived this afternoon so I can carry on with the install :thumbup: . But I need to get help lifting the scooter seat off cos it’s v.heavy and awkward. hanged
Postby terry2 » 21 Mar 2019, 10:08
Scooterman wrote:I managed both packs insulated. I’m reasonably pleased with how they’ve turned out. Shirley’s parcel arrived this afternoon so I can carry on with the install :thumbup: . But I need to get help lifting the scooter seat off cos it’s v.heavy and awkward. hanged
That's looking GREAT :D
You must have loads of room.
Well my chair nearly back together. But I can't use it!
I missed placed the Monitor ext lead. So I have 2 more coming.
Don't think they will be here till next Monday :(
Postby Scooterman » 21 Mar 2019, 10:27
Thank you. Yes I'm lucky, big scooters tend to be more accessible than powerchairs.
I was a little bit annoyed as I should have arrange the cell order in the two packs as a pair (mirror image), as it would have made the connections more symmetrical looking. But I'm not breaking one apart to do that now they're made. I always make mistakes, my brain tends to go south, czy I get SO annoyed with myself :cussing :hammer
Postby shirley_hkg » 22 Mar 2019, 03:10
@Scooterman , I leave you an open end of the net sleeve of the main charge cable . Cut the excess , drip some hot glue , and seal it with the shrink tube attached , with a hair dryer .
DON'T TRUST ANYONE . When you have finished all battery wiring , check the JST end to ensure every voltages are in proper order , BEFORE YOU PLUG IT INTO PL8.
Postby Scooterman » 22 Mar 2019, 08:38
Will do Shirley, good advice :thumbup:
You made a nice job of the cables, very professional.
Postby Scooterman » 22 Mar 2019, 11:29
Can someone check these connections please?
A while back for the links I bought 6mm pvc (fine strands) and 6mm lugs.
On hindsight I probably should have bought 10mm, but the scooter only draws 100A max continuous (single motor), and I'm a lightweight.
I was gonna double up on the series links as shown in diagram. I messed up making the second pack, cells 8 should have been where 5s are and 6 & 7 respectively.
Green are the node wires, will it balance or :ambulance
I will probably use some of shirley's thick silicone cable for 24v to controller. In diagram it's shown as 2 x 6mm
EDIT because the seat post is inbetween the two pack, the series links between 4 & 5 will be longer than the rest. There's nothing much I can do about that.
Postby shirley_hkg » 22 Mar 2019, 11:44
IT IS CORRECT !
Users browsing this forum: DennisinTexas, duke1, emilevirus and 411 guests
