Postby Scooterman » 24 Mar 2019, 10:28
Terry, when you next charge your pack can you post a picture of the cell resistances, I'm just curious as I've never seen anyone elses.
If you don't know, at the top of the graph you click view, then cell restistance.
Thanks :thumbup:
Postby Burgerman » 24 Mar 2019, 10:31
If you crimped all those inter cell connections they will be all over the place probably. If not now, in a few months.
Also its normal for 1 and/or 8 to be high, because those cells also have long charge cables added into the measured data.
Postby terry2 » 24 Mar 2019, 10:36
Burgerman wrote:If you crimped all those inter cell connections they will be all over the place probably. If not now, in a few months.
All connectors was soldered. And being so small it was a pain :D
The balance wires was soldered to. Looks like I may have to re-do some?
Is it ok to discharge them for an hour or two, then recharge?
Scooterman wrote:Terry, when you next charge your pack can you post a picture of the cell resistances, I'm just curious as I've never seen anyone elses.
Thanks :thumbup:
Will do
Postby Scooterman » 24 Mar 2019, 10:37
Burgerman wrote:Also its normal for 1 and/or 8 to be high, because those cells also have long charge cables added into the measured data.
I'm SO PLEASED you said that because 1 and 8 were slightly high and low and 2,3,4,5,6,7, were grouped together in a band. I didn't wonder whether it was due to something like what you mention, I'm glad you've cleared that up :thumbup:
EDIT: This is what I got, I hope they're okay. But the charge was done on the bench and as you say I will probably get problems down the road in the scooter if I leave them with crimped connections.
Postby Burgerman » 24 Mar 2019, 11:04
Unless you are charging like a hobby pack with 3 inch cables thats quite normal.
The cell resistance is lower than that.What you are really measuring is the charge cable and connectors mostly...
So unless one of them is drastically different ignore it.
Do you realise that 2mOhm is basically a loop of wire cable? Its extremely hard to accurately measure battery resistance at such low levels accurately. 2 milliohms is equal to just 0.002 of 1 ohm.
Postby Scooterman » 24 Mar 2019, 11:29
Wow, thank you BM that's reassuring. When I compared my measured cell resistance with the spec sheet for my cells, the spec sheet stated a much lower level, and I was worried I'd done something to damage the cells when my old PSU went up in smoke and the graph went a bit haywire, and I was still learning then so wasn't very confident in my knowledge. I'm more so now.
This is the charge from 3.5v to 3.6v. When I'd built the 2P8S pack, to get the cells to balance I had to charge each 2P cell group up to 3.5v, then hooked them back up as 2P8S and charged to 3.6v. And I was pleased they seemed to balance okay.
But I will redo the links before installing the two 12v packs in the scooter.
Postby steves1977uk » 24 Mar 2019, 12:31
Here's mine SM...
This is a 4+ year old pack made of Headway cells. Before I had it rewired and rebuilt, cell 8 would exceed 4mOhms the odd time. So you have nothing to worry about! :thumbup:
Postby Burgerman » 24 Mar 2019, 15:02
And if storing them, take out 1/3rd the capacity. So remove around 60 to 70Ah from a 180Ah pack.
Postby terry2 » 24 Mar 2019, 15:21
Do they look good or will I need to rewire some?
I did discharge it for 2.5 hours, then recharged it.
Postby Burgerman » 24 Mar 2019, 15:35
Looks OK to me.
Postby Burgerman » 24 Mar 2019, 15:37
You put back 13Ah.
What Amp ws the discharge? Around 4?
How many Ah did you put back after the ride out?
Postby terry2 » 24 Mar 2019, 15:45
Burgerman wrote:Looks OK to me.
Thanks BM. My mind is at ease now :)
Burgerman wrote:You put back 13Ah.
I haven't got that info. I discharged it with the file you gave me.
But in the morning I will do my hospital run of just under 11 miles :o
And then I will take note of all the info.
Do you think I should get a fire extinguisher...
Postby Scooterman » 24 Mar 2019, 17:02
If you make a note of your mileage tomorrow, when you recharge you'll roughly know your Ah consumption per mile which should give you an idea of the range of your pack. Obviously allowing for a safety margin.
Postby Burgerman » 24 Mar 2019, 17:13
Always wise. But they dont usually burn unless you hit them with some severe external heat. Anyway if it catches fire and you cant get out then you are likely to poo yourself. If its the right consistency that should put it out. toiletpush
Postby Scooterman » 24 Mar 2019, 17:32
That was funny :lol:
I forget, you guys can't always get out of your chair quick enough or without assistance, so I can understand the concern. I would worried too!!! But as you say BM lifepo4 is pretty safe.
With lithium battery technology, is the fire risk only when charging?
Postby Burgerman » 24 Mar 2019, 18:01
With LiFePO4 its almost non existent. Shorting them, and stuff may burn wiring, and make a lot of heat and smoke but its not easy to get them to actually burn.
With LiPo or lithium ion they can do it because of manufacturing faults like the thousands of recalled phones, laptops, hoverboards etc. Or because overcharge. Or because you charge a pack then the temp changes. Or because they leak or get punctured and let oxygen in. Or just because they feel like it... And they go better than fireworks, and for longer.
Postby terry2 » 25 Mar 2019, 11:26
:D
My appointment was cancelled. So I went on a 6 mile spin at 6 mph. Went around a few shops.
Do I just charge it now and see how much it puts back?
Should I take pictures of anything first?
Postby Burgerman » 25 Mar 2019, 11:41
That uses as much as your 6 mile spin.
Postby terry2 » 25 Mar 2019, 12:32
Burgerman wrote:Yes.
Never knew that.
It's charging now. I will post graphs after.
Postby terry2 » 25 Mar 2019, 12:51
Here is the graph
Postby Burgerman » 25 Mar 2019, 14:23
Well you used 21Ah. Out of 176?
Thats 176 div by 21 = 8.3. So you can go 8 times further than that.
So 8x your 6 mile spin and shopping is 48 miles. If you skip the shopping you can likely almost double that. But you should keep 10Ah in reserve. So call it 70 miles with 6mph running. You better take some packing up.
However, take a look at the inter cell connections when you can get chance. They should all stay relatively close together on that graph.
Postby terry2 » 25 Mar 2019, 14:30
Burgerman wrote:Well you used 21Ah. Out of 176?
However, take a look at the inter cell connections. They should all stay relatively close together on that graph.
That's fantastic news :D
I will look at cells 2 and 8 when I can get someone to life the chair up for me.
Thanks again BM.
Postby Burgerman » 25 Mar 2019, 14:35
Also you may notice just 1 hour charge. You can knock 15 mins off that if you increase 30A to 40A charge.
Postby terry2 » 25 Mar 2019, 14:46
Burgerman wrote:Also you may notice just 1 hour charge. You can knock 15 mins off that if you increase 30A to 40A charge.
I will keep that in mind ;)
Thank you to everyone for there help :worship
Postby Scooterman » 25 Mar 2019, 20:25
Stirfry copper anyone? :lol: Seasoned with white wine vinegar and a dash bicarb.
I'm not too sure about the copper, it probably will oxidise but I'll stick with it. Hopefully any oxidization will only be on exposed surfaces and mating surfaces should be air tight??? Only time will tell..............................
And as far as the links go, they're still crimped only :oops: . I'm worn out and couldn't face stripping off the heat shrink and redoing them with solder, at least not until I get better at soldering.
The cable doesn't look very thick, 6mm^ stranded pvc, but it's in parallel (1/2 current per leg) and scooter only has one motor with a 42A constant current rating.
When I had the cells on the desk to test charge I used single 2.5mm^ series links, and the links didn't even get warm with a C-rate of 20A. The 2.5mm feed cable did but not the links so I'm confident 6.5mm^ parallel will be okay.
The balance nodes lugs will go on top on the copper nuts, and then nyloc nuts over the whole lot and a smear of vaseline (petroleum jelly).
Admittedly it looks a bit 'heath robinson' but it's my first attempt and if I was to redo it or do another pack for my powerchair I would make a better attempt. Just got to install it now and mod scooter wiring a bit, and bobs your uncle, fannys a rude word! :lol:
Postby Burgerman » 25 Mar 2019, 20:30
You want problems? Use bare copper... And crimp only. You see those copper studs and nuts in that strainer bowl? They are already oxidised.
Use plated (zinc) or stainless steel bolts, And tinned ring terminals soldered.
Postby Scooterman » 25 Mar 2019, 20:32
It'll be okay! :fencing
I know they did a little bit cos I left them too long. But I gave them another dose before installing
Postby Burgerman » 25 Mar 2019, 20:34
Nope, you will LIKELY get a graph that is all wobbly and uneven looking like cell imbalance. And if not at first, in a week or two.
Postby Scooterman » 25 Mar 2019, 20:34
We'll see.....
Postby Burgerman » 25 Mar 2019, 20:38
You wont know. Because uneven balance by a few mV looks the same as cell issues. So you will be in a dilemma...
Users browsing this forum: No registered users and 285 guests
