The photo below shows a battery made by placing a strip of copper and a strip of aluminum into a glass of Coca-Cola (I used the sugar-free cherry flavored variety because that's what I found in the refrigerator).
link woody Burgerman wrote: a quick squirt of WD40 (the ONLY thing its any good for) helps prevent it oxidizing.
woodygb wrote:You might want to consider an electrical jointing compound ...
https://www.ebay.co.uk/itm/Unial-Univer ... ctupt=true
Scooterman wrote:I did a bench test, I was worried and got up at 6am. The graph looks okay, but whether it'll will stay that way over time I'll just have to see...
I wonder whether the higher cell resistance of cell 4 is due to me having two physically separated 12v packs. The series links between 4 and 5 are about 3x longer than the series links between the other cells.
Burgerman wrote:The highest one is 1.2mOhms which is nothing really.
Burgerman wrote:It may well be. But still check inter cell connectors and balance wires, connectors, etc on 4, 5 and 6. But not urgent. It may be that a squirt of switch cleaner on the connectors, or a tighten of the bolts will make it all perfect. Or it may always be that way.
terry2 wrote:Scooterman wrote:I did a bench test, I was worried and got up at 6am. The graph looks okay, but whether it'll will stay that way over time I'll just have to see...
Those are better than mine. Here is a new one from today
I did put a new cross wire on 1-2
steves1977uk wrote:terry2 wrote:Scooterman wrote:I did a bench test, I was worried and got up at 6am. The graph looks okay, but whether it'll will stay that way over time I'll just have to see...
Terry, you don't leave the cell monitor connected while charging do you?
Burgerman wrote:The monitor only takes a small current, but if connected all day it will slightly unbalance cells 1 and 2. And if set to "balance" will UNBALANCE the pack...
terry2 wrote:steves1977uk wrote:Terry, you don't leave the cell monitor connected while charging do you?
Yes I left the monitor connected![]()
Unplug it then I take it?
As long as you don't physically 'upload' your breakfast you'll be alright. Although perhaps that might not be a bad thing?Burgerman wrote:And I thought I would upload my breakfast...
Users browsing this forum: Mr.Math, saker98, sergey0, shirley_hkg, Superchunk and 548 guests
