Burgerman wrote:The monitor only takes a small current, but if connected all day it will slightly unbalance cells 1 and 2.
steves1977uk wrote:Yes SM, although I've not tried this I don't see why it shouldn't work.Although disconnecting it completely would be better if the scooter/powerchair is not in use or being charged.
Burgerman wrote:You needed to check 345 and 567 as 4 and 6 were the issues ones.
If that doesent fix it its just how it is. Not all cells are identical. Did you use switch cleaner like de-oxit ion all plugs, connectors?
Its not a major issue, use it for a few weeks.
Burgerman wrote:Remember that it cant tell you how much fuel is left. Its great for a warning when you are getting into the last 25% of your battery capacity. So not really even any need to plug it in unless you loose a light on the powerchairs display. Unless you have a reason, like a suspect cell.
Scooterman wrote:Burgerman wrote:Remember that it cant tell you how much fuel is left. Its great for a warning when you are getting into the last 25% of your battery capacity. So not really even any need to plug it in unless you loose a light on the powerchairs display. Unless you have a reason, like a suspect cell.
I'm planning on recharging according to mileage (cycle odometer). And carry a cell checker with me for the occasional voltage check, especially when getting near mileage due for recharge.
EDIT: I did away with the manual parking brake that I never used. The odometer is pretty accurate actually. The sensor is a reed switch and I counted 10 wheel revs, measured distance, divided by 10 and inputted wheel circumference in mm into dinky handle bar unit. It shows, distance, odometer, max speed, average speed, trip time, time. https://www.ebay.co.uk/itm/New-Bicycle- ... 0005.m1851
Scooterman wrote:Thanks Terry.![]()
There's also free cycle apps for phones. I have one on my phone which shows distance speed time route etc.
Scooterman wrote:Steve - that's why you suggested putting a switch in the +ve feed, or
Learning all the time![]()
shirley_hkg wrote:Scooterman wrote:Steve - that's why you suggested putting a switch in the +ve feed, or
Switch should be on the -0v wire instead .![]()
Burgerman wrote:Distance on a scooter is a better guide than on a powerchair. But be aware that it may take 10x as much energy to climb a hill for 1 mile than it does to run on the flat for 1 mile. And that decending a hill, if its steep enough, can actually put back some energy. So dont rely too much on distance covered alone. If in doubt and the battery is getting low, plug in that little alarm/meter.
If the battery is big enough, non of this stuff is a worry because you would likely die from hunger or exposure before running out of power and hurting a battery. This is one of the reasons that you SHOULD always maximise the amount of Ah you fit when replacing lead. The other is of course that the pack will last longer, can be lower C rate, can be charged less frequently esp if you forget, and so on.
With 176Ah in a powerchair, you dont need to worry much unless you are doing 2 marathons. And even then...
Burgerman wrote:can be charged less frequently esp if you forget, and so on.
Burgerman wrote:Or 200Ah ... an additional 10 miles...![]()
https://szaspower.en.alibaba.com/produc ... 1f41HzY08D
Burgerman wrote:The way to find the full capacity is to measure it.
That would mean discharging it from 100% charged to 2V per cell which is not good for them.
The safe way is to discharge to 2.9V and then estimate that theres about 5% remaining.
The PL8 can do that. And it will take 2 days...
The real issue is this.
Are the 176Ah cells, USED 200Ah cells, being sold as new 176Ah ones... We dont know. But also are the 200Ah ones the correct capacity, and the 200Ah ones typical chinese rounding up "errors" so they sell more. Few people have equipment to test. And the answer is: Nobody knows!
Users browsing this forum: emilevirus and 307 guests
