If it's digital, the only thing that matters is if the signal gets through, and as long as the wire is big enough for that, increasing the size makes no difference...
If it's an analog signal then in theory you could get less of a voltage drop across the wire if the wire were thicker, but in practice, especially over the short distances and low currents involved, I doubt you'd notice a difference. Given what I'm guessing for any analog signal currents, the existing wires are already like sending garden hose water volumes through a fire hose.... (not to mention that they can compensate for any loss in the circuit design)
Basically, as Lenny said, the only real advantage to thicker wires is better mechanical strength. However from his description, the big issue with that isn't really the strength of the wires, as much as it is that soldering makes for brittleness at the solder joint, and not having any strain relief makes that a problem.
shirley_hkg wrote:ex-Gooserider wrote:Wire thickness:
Hard to be certain, especially since I haven't started the build yet, but from the photos, I would say that the thin wires aren't really a problem as they are basically just data / signal lines that don't have to pass any significant current.... They are actually HEAVIER than they need to be electrically in order to get enough mechanical strength... The only wiring that is ever a real concern is the stuff that carries heavy current, and that looks to be AWG 10 (or metric equivalent) which is adequate for the job...
OK .
What I mean is using thicker wires for signal will improve accuracy , or worse.
No injuries, no damage to the chair, just rather embarrassing needing to have the volunteers on the trip pick the chair up and then pick me up and put me back in the chair...
Obviously it is possible to put the terminals however you like, and re-mark the front panel, but it seems a shame to mess up such a nice piece.
