expresso wrote:after making wire cables for my 80ah pack - the charge graphs are perfect - cant get any better - they were not bad before -
one pic is before - the perfect line is today after - i now know what to do if it happens again - since i added lock washers to the only 4 that were a bit stripped with larger screw - if i have to redo it again - i will add all lock washers with a touch of locktite and all get larger 10mm screws - change the one wire cable thats not bent - and that should be it -
very happy with these 80ah Cells so far
Scooterman wrote:You've got nice hands Terry. Mine are filthy and cut to pieces
Thank you Woody, but I saw your post too late. What you linked to looks perfect!!!
I ordered this https://www.ebay.co.uk/itm/1-mm-A4-Lexa ... 2749.l2649 this morning. I'll give it a go, but if it doesn't work I won't have lost much and will order that screen.
Burgerman wrote:How flexible? Like a cable?
shirley_hkg wrote: I'd open up shrink tube to see one inside.
LROBBINS wrote:Terri,
at least they are tinned so you shouldn't have any problem with copper oxidation
Scooterman wrote:Fingers crossed for you Terry![]()
I really hope you get a good graph, I'm hopefully confident for you. Hard work deserves reward.
If you remember can you also post the resistance graph as well
Scooterman wrote:Internal Resistance is really low Terry, that's great![]()
I don't know why them two cells shot high first, BM will know (and Shirley will know too).
I wonder whether it's because:
a) they are weaker cells and have higher resistance so voltage shot high first, although IR looks great.
b) they are stronger cells and discharged less so became full soonest.
BM will be able to answer, I'm interested
terry2 wrote:
Glad you said the "Internal Resistance " is ok. As I haven't got a clue what it is![]()
Your IR is the lowest I've seen, it's fan dabby dozy![]()
The lower IR the better![]()
Re discharge to 2.9v. It will take a couple of days terry, and if you don't like fan noise do it in a room you don't sit in.
shirley_hkg wrote: Experience tells the weaker cells rise sooner . The IR seems too good to be true to me also . PL8 is not good at this.
Switch to MONITOR as soon as recharge ended , to log the voltage drop and graph it for an hour or two .
Discharge the entire pack as one to 2.95V to find out . You will be well rewarded.
Imagine 'someone', say 'a manufacturer' just for a laugh, came up with a modular design that lets you add the motors & wheels, casters, seat and armrests to the battery box that suits your needs best, with that battery box being the structural base frame.
You'd transplant the parts to a new battery box with more cells as you grow (kids could even start with less ah I assume) or as your budget or mobility needs change...
It's basically the BM design without the tubular frame but with the casters and seat to be attached to the battery box as well.
You can choose a layout based on your budget, your size, your activity... anything really.
expresso wrote:thanks Scooterman - Terry - time will tell if my pack lasts and dosnt change - if it does - i know what it is and will fix it better -
Terry worse case your Cells are just a bit different - but as long as you can use your Chair all day and not worry - and recharges fine etc,
its a hit and miss with these Cells - now unless you want to really rip the pack apart and test each cell - then rebuild - better connections etc,
thats alot of work - may not be needed at all - follow what BM and Shirley suggest - they usually correct
terry2 wrote:Here is the graph from monitoring. Any thing stick out?
Scooterman wrote:terry2 wrote:Here is the graph from monitoring. Any thing stick out?
Nope, not as far as I can see![]()
Are you going to do a deeeeeeeeeeeep discharge?
shirley_hkg wrote: It is safe to run overnight , at least in discharge wise .
terry2 wrote:Just an update
It's been discharging for 19Hrs and 55 mins. OUT=72513 Cells are 3.272
A long way to go yet
Scooterman wrote:terry2 wrote:Just an update
Sometime tomorrow late afternoon I would guess?
Is the fan noise getting on your nerves yet?
terry2 wrote:
I have lifted the four corners of the PL8 to let the air blow out and about.
Scooterman wrote:No, nothing wrong with that Terry, keep going
Burgerman wrote:You will know when its done. If you are using a preset I sent you, it should stop when the lowest cell drops to 2.90V and they will start to fall suddenly. THEN read the capacity, and you will know how much Ah you REALLY have. And which cell is the smallest capacity. The one that drops first.
Just go to the presets, discharge tab, check that it is set to 2.900V per cell. You cant change it without stopping discharge though... So dont.
Users browsing this forum: acid_coke, Bing [Bot] and 329 guests
