Re: PGDT interface update
Postby rustyjames » 01 Mar 2014, 17:09
Got it done, Thanks for the input everyone. I used a combination of tools, heat and teeth!
@ ex-gooserider: both, stripping jacket and those blonde hair thin wires.
@ Will: you know the deal, it's like working with mitten's on. Perseverance, patience and time.
rustyjames
Postby Burgerman » 01 Mar 2014, 17:14
Train up a young, small fit blonde carer? :)
Postby rustyjames » 01 Mar 2014, 17:20
Yes, fingernails!
rustyjames
Postby rustyjames » 04 Mar 2014, 19:57
So, I know virtually nothing about electronics, and this is probably a dumb question, but I have to ask: when connecting the RX/TX wires to the XLR connector can I solder in the diode stem with the RX wire? Or, does the TX wire with diode need to be soldered into RX wire and just that wire soldered into the XLR?
Hope that made sense :?
rustyjames
Postby Burgerman » 08 Mar 2014, 02:17
None! :?
:shock: :lol:
Postby ex-Gooserider » 08 Mar 2014, 04:31
I haven't looked back at the schematic, but in general, the rule is that all points along a wire that connects two parts are the same. So when someone draws a schematic you put the connection points where it is 'best' from a standpoint of getting the best clarity, and some level of "artistic niceness". Similarly when building the actual circuit, you place the parts and wires in whatever physical arrangement is neatest / easiest / cleanest to build, as long as you match the schematic...
There are "gotchas" and stuff gets much more complex when dealing with high frequencies, but that isn't a factor in something like this cable.
The orientation of the diode is very important - pay close attention to which end has the band, but as long as it's pointed in the right direction it doesn't matter just how you actually arrange the connections.
Postby rustyjames » 08 Mar 2014, 16:58
@ Burgerman :lol:
Thanks, ex-gooserider. I did manage to get it all done. Now I just have to fiddle with getting the proper driver installed. I'm working it :ugeek:
rustyjames
Postby woodygb » 08 Mar 2014, 21:06
Installation instructions.. including a driver download that I've found best for the install of a compatible driver.
http://www.crercc.com/comport.html
Postby rustyjames » 09 Mar 2014, 02:32
Thanks Woody, I do remember you posted that before but had forgotten about it.
rustyjames
Postby rustyjames » 17 Mar 2014, 19:22
OK, so it snowed again I had some time to play with my cable and programming today -- to no avail :P
Here's where I'm at--Windows 7 Home Premium 64 bit:
--Prolific 3.2.0.0 Driver installed and working properly
--Serial Comm Port 3
--Run PGDT software
--Tools>Comms> enter 3 in serial port configuration
COMMS INNACTIVE :cry:
Any suggestions, other than wait for Woody's cable to arrive? :lol:
rustyjames
Postby woodygb » 17 Mar 2014, 19:58
Did you pop the case?
The lead that I've just constructed for you had the wire colours reversed to what is shown in my pic.... Green was TX & White was RX
So ...If you didn't go the case popping route ... I'd try swapping the diode into the other wire.
Postby rustyjames » 17 Mar 2014, 20:09
No, I didn't pop the case because I did it at home and don't have a vice handy here (your method described earlier). When I get over to my shop I'll try popping the cover.
Thanks.
rustyjames
Postby Driveraider » 23 Mar 2014, 02:53
I am trying to acquire the parts to build or even buy an interface cable in the US for a Pride Jet 3 Ultra with a VSI controller. I don't care if it is serial or USB, but I am hesitate to ask PGDT what they would charge... I saw some of the posts talking using baofeng/kenwood USB programming cables. I have seen them for 6-7 USD, but it appears to be a gamble if it is a knock off or not. If the price is right, I would gladly pay for someones hard work.
Driveraider
Postby Burgerman » 27 Mar 2014, 10:30
Everything you need to know is in this thread. Although a bit confused in places.
Postby woodygb » 27 Mar 2014, 11:02
I did P.M. him ..but no reply.
Postby Burgerman » 06 Apr 2014, 17:42
Still bug free, fault free and working good here.
Postby rustyjames » 07 Apr 2014, 17:34
:D I got a package from Woody the other day :D with a programming cable, (and a couple RC thingy's). So I tried it out and "COMMS ACTIVE" :D
Thanks again Woody!
rustyjames
Postby jehan » 14 Apr 2014, 10:09
Many thanks to Woody, John And everyone in this post.
I'm all set to try it out on a vr2 controller. It's definitely a case of the wheelchair driving me rather than me driving the wheelchair.
I would like to run through parts required
Kenwood KPG-4 Replacement USB RIB-Less Programming Cable
1N4148 diode
Neutrik/XLR plug
Prolific 3.2.0 Windows driver (Running Windows 7 64-bit)
Programmer software OEM level (PG drives technology PC program version 14.4.3 Is the one I have)
I'm going to source the Kenwood programming cable locally With the diode before I try From radio Arena Which will take a month to arrive.
Please let me know If I'm good to go??
jehan
Postby Burgerman » 14 Apr 2014, 10:21
Looks good to me!
Postby woodygb » 14 Apr 2014, 10:49
I've had success with the cheaper Beofeng / Baofeng UV-5R Wouxun usb cable.
http://www.ebay.co.uk/sch/i.html?_sacat ... _PrefLoc=2
Postby rustyjames » 14 Apr 2014, 22:51
As I reported earlier I had easy success with Woody's cable for Windows 7. Today I finally had a chance to try it out on my other laptop with Windows XP. It went just as easy, COMMS Active :D Thanks again Woody!
rustyjames
Postby jehan » 16 Apr 2014, 11:26
Thanks John, though my PC programmer software says it's the service version.
Woody, my initial search for the USB radio cable is not looking good. Will most likely have to order from eBay or radio Arena. In which case I would much rather get a working cable from you.
However, I was able to find the Neutrik XLR male plug After John tip to look in a microphone store.
Any idea What kind of store would have the USB radio cable?
jehan
Postby erreipnaej » 16 Apr 2014, 12:34
Hello,
I get a cable from Arena (Black, red & white cable).
I tried all connection possibilities with two diode orientation and it never worked on Windows seven (always COMMS INNACTIVE :cry: )
I'll try again this evening with an XP computer.
Does somebody have the pinout of the PGDT cable (RS232 to XLR) as I have plenty of different USB to RS232 adapters?
Thanks for your help.
erreipnaej
Postby woodygb » 16 Apr 2014, 13:25
There is no pin out for a RS232( Serial signal )- PGDT XLR ( TTL signal ).
If you'd like to post me your cable I could see if I can sort it out ... NO CHARGE ...except you pay postage both ways.
Have the PL2303 drivers installed correctly? .... and did you use those from the recommended download listed on this thread?
Postby woodygb » 16 Apr 2014, 13:39
jehan wrote:.
http://www.amazon.in/BaoFeng-Baofeng-Pr ... feng+cable
Postby erreipnaej » 16 Apr 2014, 15:30
Hello Woody,
woodygb wrote:There is no pin out for a RS232( Serial signal )- PGDT XLR ( TTL signal ).
If I well understand there are some electronic components in the orginal PGDT cable (RS232 to XLR3).
I understood after reading better the complete thread that driver release has some importance.
I'll investigate on both machines (XP and Seven) to get the sotware working.
As I'll be in easter holidays next week, I'll will have some time.
Is there some specific setting for the COM port regarding to baud rate, stop bit, parity and flow control to change?
If I don't succeed, I will contact you for your kind help regarding the cable testing.
Best regards.
Jean Pierre
erreipnaej
Postby woodygb » 16 Apr 2014, 16:21
You probably could connect the RS232 port to the XLR with various extra components that must amongst other things convert the Serial signal to a TTL signal.
NO settings are required for the USB ( other than the driver ) ..it either works or it doesn't.
I recommend the drivers from this link ... http://www.crercc.com/comport.html
Postby erreipnaej » 16 Apr 2014, 21:59
Hello Woody,
The cable is working. After testing all diode orientation and wiring possibilities on a solderless breadboard I found the correct connection.
That works!!! I've got COMM ACTIVE message. :D
Now the longer remains to do: Set the wheelchair properly adapted to my son capabilities.
I already change a few settings and reaction seems better.
I'll compare the OttoBock B400 settings with the one from the former OttoBock A200 he had and adapt to give him a soft drive.
Thanks a lot for your support and explanations.
Knowing some guy is ready to help and assist is a great reconfort.
Thanks to you and of course to Burgerman.
Best regards.
Jean Pierre
erreipnaej
Postby jehan » 17 Apr 2014, 08:39
Thanks for the link Woody. I never thought to look in Amazon India. I contacted them and they have indicated a delivery period of 1 to 4 weeks! Seems like they consolidate their imports Every couple of weeks.
If you have a spare cable , Let me know and we try to find a way to get it across.Otherwise, I'm fine to order with them.
jehan
Postby woodygb » 17 Apr 2014, 08:50
I have one unmodified cable kicking around ...& I'm happy to post to anywhere in the World.
Should you wish to purchase a ready made one ...Private email me to discuss price , payment etc.
Users browsing this forum: jefferso, jehan and 433 guests
