Postby terry2 » 15 Jul 2019, 13:51
Burgerman wrote:It will be your connections, or if you crimp stuff - that.
Does it charge and drive normally?
If so dont worry much. Its VERY hard to get accurate resistance readings on susch low values.
Thanks BM.
It charges just fine and the cell voltage is spot on.
It drives great with loads of torque.
I am just checking all connections now will post a graph when the pack has recharged.
I should of said that when discharging the cell resistance is the same as teh other cells.
Postby Burgerman » 15 Jul 2019, 14:15
Then ignore it. It may just be a dirty balance connector plug at the SUB D or at the PL8 or wharever. Ignore it.
Ot buy switch cleaner. Everything soldered? Hopefully no crimps...
Postby terry2 » 15 Jul 2019, 14:36
Burgerman wrote:Then ignore it. It may just be a dirty balance connector plug at the SUB D or at the PL8 or wharever. Ignore it.
Yeh. Everything is soldered.
I will use contact cleaner on in a bit.
I'm just discharging them to 3.3
Postby Burgerman » 15 Jul 2019, 16:33
Why?
Postby terry2 » 15 Jul 2019, 17:45
Burgerman wrote:Why?
Because I want ted to check all connections. Then recharge.
But My PL8 has turned itself off :fencing
I get an Over Current protection on the power supply LCD.
I don't surpose there is a way to fix it?
That's all I need today banghead
Postby Burgerman » 15 Jul 2019, 19:09
Whats the max current of the power supply?
Set the PL8 to less in the SUPPLY tab.
Postby terry2 » 15 Jul 2019, 19:41
Burgerman wrote:Whats the max current of the power supply?
It's a Efuel 1200w 30 amp.
I will try what you said and report back.
Postby terry2 » 15 Jul 2019, 20:14
As soon as I turn on the power supply I get the error.
The PL8 won't even turn on. No lights no nothing.
Postby steves1977uk » 15 Jul 2019, 20:24
Are you sure it's 30A Terry? My EFUEL PSU is 50A@24v. Do you have another PSU to test with?
Postby terry2 » 15 Jul 2019, 21:13
Yes it's a 30AMP 1200W.
The power supply comes on OK if I don't connect the PL8.
As soon as I connect the PL8 I get and error.
It was working great. Then the LCD on the PL8 went off. Look likes it's dead.
Wonder if there is a fuse in side?
Postby Irving » 15 Jul 2019, 21:50
Are you saying that the PSU doesn't come on and/or shuts down when the PL8 is connected?
First verify the PSU can supply power to a load... Try powering something else, or charging a battery.
Also try powering the PL8 from a 12v battery.
Postby steves1977uk » 15 Jul 2019, 21:59
Is this the power supply you have Terry?
If it's blowing it's internal fuse, then there's a possibility it has developed a fault. In which case it's better to buy a Shirley ZXD2400 PSU which is better quality.
Postby Burgerman » 15 Jul 2019, 23:09
Could be the pl8 has gone short circuit. Or the power supply. So I suggest you do as lenny says.
Postby snaker » 16 Jul 2019, 01:28
It is very similar what happened to my old PL8. I thought the PSU failed and tried another PSU but it still remained. Finally, it was a failure inside the PL8. All its mosfets at input were broken.
Postby terry2 » 16 Jul 2019, 08:23
Irving wrote:Are you saying that the PSU doesn't come on and/or shuts down when the PL8 is connected?
steves1977uk wrote:Is this the power supply you have Terry?
Burgerman wrote:Could be the pl8 has gone short circuit. Or the power supply. So I suggest you do as lenny says.
snaker wrote:It is very similar what happened to my old PL8. I thought the PSU failed and tried another PSU but it still remained. Finally, it was a failure inside the PL8. All its mosfets at input were broken.
Thanks a load guys.
My carer came in this morning and reminded me that I had a spare PL8 :oops:
I plugged it in to the same charger and it works as should. So my 1 PL8 has died :thumbdown:
Time for a teardown of the dead PL8.
Thanks again.
Postby Burgerman » 16 Jul 2019, 10:18
For future reference you should always power the PL8 before connecting the chair or battery. Is it under warranty?
Postby terry2 » 16 Jul 2019, 10:33
Burgerman wrote:For future reference you should always power the PL8 before connecting the chair or battery. Is it under warranty?
It was off ebay. So no.
And it was charging when the it died.
I have checked the 2 40amp fuses and they seam to be ok.
But why did they solder the fuses on the board?
I mean if this was a £50 cheap Chinese rip off. One would expect it.
But not for £350+ :fencing
Does anyone know of a service centre in the UK?
Postby steves1977uk » 16 Jul 2019, 11:44
Don't think there's a repair service in the UK Terry :thumbdown: Usually you have to send the PL8 back to Singapore for repair. czy You'd think Revolectrix would have an UK/European service centre. :cussing
Postby terry2 » 16 Jul 2019, 11:54
steves1977uk wrote:Don't think there's a repair service in the UK Terry :thumbdown: Usually you have to send the PL8 back to Singapore for repair. czy You'd think Revolectrix would have an UK/European service centre. :cussing
It does seam strange that they have no EU\UK warehouse.
I found out that hobby king did a licensed clone of the PL8 called the turnigy fatboy 8 for £150!
But they don't stock them now.
There must be another charger just as good?
Postby Irving » 16 Jul 2019, 11:55
They are OK because your PSU is limited to 30A. They are soldered in because its an 80A failsafe to protect wiring, they rely on current limiting at the PSU for 'normal' overcurrent situations.
The fact that the fuses are OK and no smoke suggests the fault is going to be subtle, i doubt you'll see anything on a visual teardown. Its going to take some understanding of how buck/boost DC-DC Converters work and a good test meter/scope setup to identify let alone rectify the fault.
Postby terry2 » 16 Jul 2019, 12:05
I have emailed there Singapore place.
10/1 says I will have to buy a new one.
Is this the only charger that can do our cells?
HobbyKing has lots. But I have no idea which one. But they are all very cheap!
Postby Burgerman » 16 Jul 2019, 12:34
Yes it is, the rest are all garbage. Thats why they are cheap. Even then the PL8 is only good after me spending years arguing about firmware changes and profile restrictions lifting etc. Now it works! They are cheap, mostly reliable, for what they do. I have 4. Used all the time for hobby, tools, cameras, AA cells, 5 chairs, van etc and all still work fine after 5? years.
Postby terry2 » 16 Jul 2019, 13:08
Burgerman wrote:Yes it is, the rest are all garbage. Thats why they are cheap. Even then the PL8 is only good after me spending years arguing about firmware changes and profile restrictions lifting etc. Now it works! They are cheap, mostly reliable, for what they do. I have 4. Used all the time for hobby, tools, cameras, AA cells, 5 chairs, van etc and all still work fine after 5? years.
All true. But. If the pl8 dies after a year one is up shit creek with out a padded.
As there is no EU\UK Wearhouse or service centre. It is strange.
And hobbyking done the turnigy fatboy 8 for £150! Which was a PL8 1 in reality.
Postby steves1977uk » 16 Jul 2019, 15:15
My first PL8 is still going strong after 4.5+ years use, but as BM says always power up the PL8 first before connecting any batteries to it. That way you are more unlilkely to have PL8 failures.
Postby terry2 » 16 Jul 2019, 16:42
https://www.jusbnme.com/index.php?main_ ... s_id=19537
Worth a punt?
I don't trust that site. So still looking :)
Postby steves1977uk » 16 Jul 2019, 16:51
Hmm, I'd be wary buying anything from that website. Best to buy from the Revolectrix International Store... http://www.store.revolectrix.com/Produc ... C5-version
Postby terry2 » 16 Jul 2019, 16:52
steves1977uk wrote:Hmm, I'd be wary buying anything from that website. Best to buy from the Revolectrix International Store.
Your right.
Cheapest so far is about £290 in the UK
Postby steves1977uk » 16 Jul 2019, 17:04
See my link above Terry. :thumbup: It's actually cheaper to buy from Singapore than the UK!
Postby terry2 » 16 Jul 2019, 18:05
steves1977uk wrote:See my link above Terry. :thumbup: It's actually cheaper to buy from Singapore than the UK!
The last time I bought off them I had loads of import tax and vat.
Or do you know away around it?
Postby terry2 » 16 Jul 2019, 18:16
Also. If it goes wrong in the first year.
It will have to go back to Singapore.
Users browsing this forum: Burgerman and 127 guests
