Burgerman wrote:When you search for bearing add RS or look for it. It means Rubber Sealed. And 2RS mans each side.
The ones you link to are zz so have a metal oil splash shield and are not sealed.
Burgerman wrote:https://www.amazon.co.uk/J-Bonest-Stainless-Electronic-Measuring-Resistant/dp/B01N7CW7LQ/ref=pd_vtph_328_tr_t_2?_encoding=UTF8&psc=1&refRID=MQZXQYHTJVWTTDMJ0YK4
I may be tempted to spend a little extra after reading reviews of super cheap ones. Like this?
Can lowering the PSI and the wheel to the lower hole on the fork help the wheel wooble issue ? or make no difference ?
Burgerman wrote:Test wheelies on grass. Its just as embarrassing as you tip over the rear, but its less painful! Ask me how I know!
shirley_hkg wrote: Long forks + big caster raised your front MORE than that of your rear wheel did . The geometry of the chair is deformed .
Lower the front and move the caster axle rearwards as much as possible , by drilling another hole .
Burgerman wrote:Why do you think longer bolts will add "pressure"? Confused here...
Pressure to bearings? Weight on casters?
If you reduce all 4 tyre pressures substantially, it will drive nicer and stop the shimmy. By as much as it takes!
Also, if the RIGHT front caster shakes, reduce pressure in the right REAR tyre by 10 or 15 percent. These chairs are not built accurately. The caster that shakes is usually the one with the least weight.
Its all I did to cure this:
http://www.wheelchairdriver.com/BM3-con ... -shake.mp4 This shakes at 12 or 14 mph here only going up hill as here. Lowering all 4 tyre pressures, and esp the rear left more cured it completely. Now I go 16mph and no problems.
Watch the 2nd half, see how soft my tyres are! And why! Admittedly easier on 3.00 x 4 tyres.
http://www.wheelchairdriver.com/gopro/soft.mp4
Burgerman wrote:If its slight and only at full speed it will go away on its own as the tyres wear in. Probably.
Burgerman wrote:You fuss a lot. Take charge! Air wont come out? Remove valve core. Re-inflate to lower pressure. Start too low on all 4, so they look a little flat. Like a cars tyre. Test. Add more as needed. When it behaves as you want, stop!
i was half way up - a bit more and my front end lifted too high and i was stuck up all the way facing the sky for a few moments -
i wasn't able to move the chair or i may have flipped over - lucky for me a biker was around and lowered my front end down - i turned around and went back
Users browsing this forum: Andrey, LROBBINS, shirley_hkg and 157 guests
