Postby Scooterman » 19 Dec 2019, 08:11
Nice looking chair. :thumbup: Is you's the top of the range version?
It must have the same turning circle as a small scooter going in reverse.
How stable does it feel at speed compared say to a RWD powerchair.
Does the way it turns take a bit of getting used to?
PS: you could always hook up 8 additional lifepo4 cells to the 176Ah's
Postby terry2 » 19 Dec 2019, 10:41
Scooterman wrote:Nice looking chair. :thumbup: Is you's the top of the range version?
Mine is the standard version. With the latest version of the frame and R-Net updates.
It's stable as my RWD Puma. Even at 11 MPH it was fine.
It's a bit longer then my Puma 40. But it does not cause me any problems. Just come from the dentist. My chair was fine :)
Having a rear steer will take me a few trips out to get used to. But no more then when I first used a chair.
I don't think I need more cells. The BEAST(that's it's name) has one 950W motor and a very small one for the rack and pinion at the back.
Postby Scooterman » 19 Dec 2019, 12:52
My scooter has an 800w (continuous) motor. It gets hot to the touch but doesn’t take the skin off your fingers! Lol
Upload some photos of of chair sometime :thumbup:
Postby terry2 » 20 Dec 2019, 12:39
Scooterman wrote:My scooter has an 800w (continuous) motor. It gets hot to the touch but doesn’t take the skin off your fingers! Lol
viewtopic.php?f=6&t=9393
Postby ICEUK » 24 Dec 2019, 19:41
Did anyone find a good source for the 105ah lithium batteries and if so what price?
Thx
ICEUK
Postby ICEUK » 26 Dec 2019, 20:33
I found these 105ah, do they look ok? I have the pdf file but cant upload it to forum
Casing material for single cell Aluminum shell
Nominal Voltage 3.2V
Capacity 105Ah
Core size D36*W130*H200MM
Cell Weight 1.98KG
Charging Current Standard Charging:0.2C
Max Charging:1C
Max Discharging Rate Max Discharging:2C
Cut-off Voltage Charging:3.65V
Discharging:2.5V
Internal Resistance ≤ 1.5mΩ (At 0.2C rate, 2.0V cut-off)
Working Temperature Charging: -10℃~55℃
Discharging: -20℃~70℃
Storage Temperature ≤1month: -10–45℃
≤3month: 0–30℃
≤6month: 20±5℃
Life Cycle >6000 times
ICEUK
Postby Burgerman » 26 Dec 2019, 21:49
Yep.
Postby ICEUK » 28 Dec 2019, 19:38
I managed to get them down to $1279. Or £977 All shipping and import taxes included. Sounds about right to me. 16 x 105ah batteries.
ICEUK
Postby Burgerman » 28 Dec 2019, 20:56
Call it 1k.
Its double the cost approx of 74Ah MKs. https://www.tayna.co.uk/mobility-batter ... 24-sldgft/
Of which just 40Ah is accessible, and 9 months working life at best if you DO access all that huge 40Ah daily. At least thats what I get.
You got 5x the usable Ah for the same cost as 2 sets of MKs.
Over 18 months, thats the SAME cost. (9 months and they are showing less range)
Over 36 months then, 2x the cost of your lithiums.
Over 9 years (LiFePO4 has been working that long here already) thats a huge 6x the cost!
And that 6x the cost is for just 40 usable Ah. You got 200+Ah!
So you got 5x the amount of fuel, or 5x the range for 6x less cost over a decade. Thats 30x cheaper in real terms after a decade Ah per Ah.
You must add the cost of a charger to that. But then you must add the cost of your mobility charger to that lead price too. You bought that when you bought the chair. And at silly cost.
Postby ICEUK » 28 Dec 2019, 21:32
Thx BM.
I have read your posts before regarding the advantages over lead, i am sold on the idea a long time ago. I have a PL8 already as I fly helis. I will order them up tomorrow and I shall report back when the arrive.
Thx
ICEUK
Postby shirley_hkg » 03 Jan 2020, 11:14
Screwed up by the extra 75Ah pouch cells, move forward to a pack with 24 EVE LF-105 cells; ie 3p8s @24V 300Ah (usable) .
This is the bottom layer. cheers
drunk2
Postby shirley_hkg » 04 Jan 2020, 15:08
Top layer completed.
Time to fully charge and balance it. cheers
Postby Burgerman » 04 Jan 2020, 15:09
You should make it to the UK by road.
Postby steves1977uk » 04 Jan 2020, 15:19
Nice going Shirley! :thumbup: You should be good for 120 miles+ with that pack! drunk2 :mrgreen:
Postby Burgerman » 04 Jan 2020, 15:25
Hes getting ready to do a runner when the chinese take over HK later this year. I hope not. :argument
Postby shirley_hkg » 06 Jan 2020, 08:35
Not bad to be prepared ! cheers
Postby ex-Gooserider » 07 Jan 2020, 01:28
I heard something on BBC that HK has gotten a new boss - just hope it isn't a case of "Meet the new boss, same as the old boss..."
I don't know how much we need to worry about censorship, but I know that I have been hearing VERY mixed stories about the situation in HK, and I'd love to hear some about what is really happening if that can be done w/o causing problems...
But from listening to BBC and the US media it sounds like the place is going up in flames or being thrown at the cops, one brick at a time....
Other stuff I've seen says that outside of the actual demonstrations it is 'life as normal'....
I'm sure the reality is somewhere in between and I'd love to hear more from a less biased source....
Postby shirley_hkg » 09 Jan 2020, 04:32
Our daily life is not much affected , except in areas during demonstration .
Economy downturn is expected after Chinese New Year .
Crazy acts include attacking tourists ; vandalize everything , including the historic HSBC lion statues . What a fool !
banghead
Postby shirley_hkg » 10 Jan 2020, 08:41
I sold my refurbished PL8, used for 3yrs, and open box of another one brand new.
Keep measuring capacity of the rest of the EVE LF-105 lot, under the same settings.
Now all resulted in over 101Ah , up to 102Ah.
Hope this new PL8 is accurate , while the previous one is 1.5% under-rated. cheers
Postby terry2 » 10 Jan 2020, 10:08
That's a massive pack :D
How do I match the cells or what ever it's called?
Postby Irving » 10 Jan 2020, 10:23
terry2 wrote:How do I match the cells or what ever it's called?
After initial charge of cells individually, noting cell capacity of each, leave alone for a couple of weeks, preferably longer, then top up each again to see how much self-discharge has occurred. Group cells in pairs matching self-discharge rate as best as possible. Then charge & balance whole pack.
Postby Burgerman » 10 Jan 2020, 13:10
He means so that each parallel pair, match the other parallel pairs. So that all 8 groups end up with the same or as close as possible, the same self discharge across the pack. Then the 8 groups should not go out of balance as fast over time.
Postby terry2 » 10 Jan 2020, 13:36
Thanks guys.
Postby Burgerman » 10 Jan 2020, 14:04
Fully charge each cell, with the same settings. Then remove say 5Ah from each cell. Be exact. If you fail, and take say 4990mAh out, or 5200mAh then write it on the cell. Ant thats fine. Dont be more out than a few hundred mA.
Do all.
Wait a month if your patience allows.
Then charge each cell individually. And make a note of the exact mAh returned. And write that on each cell under the first figure. It should be a larger amount. The difference is what it lost.
Write that under the two figures...
Postby shirley_hkg » 12 Jan 2020, 08:12
Did a capacity test to my Mega_Pack
@3.605V ⇒ 3.00V.
Out of one single reservoir , have to dump it to my two empty chairs by 2 sessions.
175.518 + 125.074.
Total : 300.592Ah.
(real usable @3.006V lowest, pack voltage at 24V , without harm done to cells)
End of race. hanged cheers drunk2
Postby Burgerman » 12 Jan 2020, 10:51
That rediculous. :clap
Postby shirley_hkg » 13 Jan 2020, 02:21
Put back 307Ah (15.00 + 292.795)
Postby terry2 » 13 Jan 2020, 11:04
shirley_hkg wrote: Put back 307Ah (15.00 + 292.795)
:worship cheers
Postby Burgerman » 13 Jan 2020, 14:00
Hes going to run out of HK before he runs out of battery. :ak47
He may need to escape to the phillipines or taiwan soon. Shame it doesent float...
Postby LROBBINS » 13 Jan 2020, 15:34
Next project for Shirley: a hidden inflatable raft and a propeller add-on.
Users browsing this forum: Burgerman, Kande_ian, LROBBINS and 105 guests
