Postby terry2 » 09 Nov 2020, 19:35
terry2 wrote:
steves1977uk wrote:Here... https://uk.banggood.com/Revolectrix-Cel ... rehouse=CN
But I think Terry wants cheap and cheerful. :eh:
Wrong again Steve.
That's 5 times now :lol:
I have one from there on back order(so has another person here).
They don't know when they will have stock.
And Revolectrix don't know when they will be selling them again. :)
It has been nearly a year since you could buy new PL8s
Postby terry2 » 11 Nov 2020, 09:44
I just canceled my order for a PL8 with banggood as the date now says Dec 6th.
The date seams to switch very often.
Postby Burgerman » 11 Nov 2020, 12:08
They do seem a bit scarce. Not even any used ones about.
Postby terry2 » 11 Nov 2020, 12:52
Burgerman wrote:They do seem a bit scarce. Not even any used ones about.
It will be a year next month since they had PL8s for sale.
They keep saying it's because of the chinese virus, but we know that's BS.
Postby Burgerman » 11 Nov 2020, 13:50
Actually its probably a mix of things. The first being that the bulk of sales is in the northern hemisphere. And sales over winter drop to almost nothing when no flying going on. So hey run stock down to zero and dont reorder anything till spring. Dead money costs! When spring came so did the virus. Every damned thing I order is out of stock. So maybe some truth.
Postby terry2 » 11 Nov 2020, 14:04
Burgerman wrote:Actually its probably a mix of things. The first being that the bulk of sales is in the northern hemisphere. And sales over winter drop to almost nothing when no flying going on. So hey run stock down to zero and dont reorder anything till spring. Dead money costs! When spring came so did the virus. Every damned thing I order is out of stock. So maybe some truth.
They didn't make any after (approx) july last year.
Then They sold all there stock + all the refurbs.
They ran out way before the virus hit.
So they either are trying to push people to the NFC type of charger, or they're going to replace it.
I can see no shortage of any electrical component coming out of china.
Postby Burgerman » 11 Nov 2020, 20:33
They wouldnt start reordering and remanufacturing befor spring. So I doubt thats the case. Its still by far the most capable of any of the chargers they sell. They sell less of them, because most people want the cheaper dumbed down ones with no PC softwre.
Postby terry2 » 16 Dec 2020, 17:26
My cells are nearly @3.0V so I think it's time to charge them back up.
Need some help with the option in the PL8 software as I have forgot what my old PL8 settings was before it died.
I have a 2400W power supply wich is 100amp.
I want to charge them slow, not full speed as I did last time....to much heat from the wires.
So what should I put in the settings for a slow charge?
Thanks in advance.
Looking at the preset tab, it's set to 30amp...can I change that to 20amp to slow things down?
Postby Burgerman » 16 Dec 2020, 17:49
Yes. Why? I charge at 40A all the time.
Postby terry2 » 16 Dec 2020, 20:34
Burgerman wrote:Yes. Why? I charge at 40A all the time.
At 30amps those red/black wires are to hot for my liking.
Postby Burgerman » 16 Dec 2020, 22:07
They are silicone. They are silicone for a reason. So they can be small and not burn up or damage the insulation at higher currents. Its not a problem.
Silicone wires were used in the hobby world because our tiny helicopter and plane electric motors take much power!
The 12 guage silicone wire is often used at over 100A without problem.
Lookup 12 awg here: They say 70A. Thats actually conservative. Does it get hot? Yep! Its designed to. Thats why they use non melting silicone.
Postby shirley_hkg » 17 Dec 2020, 06:18
Yes Terry. You can.
I charge at lower rate even. I spread the charge across the whole night.
Postby shirley_hkg » 17 Dec 2020, 06:29
Hi folks , someone has posted a link to a site that can work out the most even combination of cell capacity in building battery pack.
Just recently , but lost track of it. Any clue ? cheers
Postby Burgerman » 17 Dec 2020, 08:15
You can charge slower too. But at say 20A it takes 10 full hours to charge a 200Ah pack plus balance and say half hour at CV. So maybe 12 hours to charge if heavily discharged.
So 30A cuts a third off that time. So a sensible 8 hour overnight.
And 40A cuts it in half compared to 20A. So 6 hours?
You need to remember that we are not putting a few Ah back. Like a lead chair. So charging at low amps is like charging a lead chair with a small 3 or 5A charger.
Postby terry2 » 17 Dec 2020, 15:10
Yes Terry. You can.
Thanks.
I am getting a error safety code 34 bad cell count.
WTF is that?
Loaded the wrong profile :(
Postby terry2 » 17 Dec 2020, 22:22
My mins is not working at the moment.
I have put back so far 164147 mAh is that about 160 amps put back in?
Postby steves1977uk » 17 Dec 2020, 23:08
Yes, it's about 164.15Ah Terry. :thumbup:
Postby terry2 » 18 Dec 2020, 05:41
steves1977uk wrote:Yes, it's about 164.15Ah Terry. :thumbup:
Thank you very much Steve :)
Postby expresso » 26 Jan 2021, 02:07
https://hhpower.en.alibaba.com/?spm=a27 ... 3e5fKm7nyH
just received my new cells - so far look packed very well - each box should have 3 200ah cells - looks way over stuffed - thats good
Postby expresso » 26 Jan 2021, 02:53
they look good - and fit in the stock battery tray - with room to spare on the sides -
Postby expresso » 26 Jan 2021, 02:54
pack very well not a scratch or dent on any of them - will start testing for Cap tomorrow
will charge fully - then discharge to 2.9v and recharge - they all tested 3.3v
Postby Burgerman » 26 Jan 2021, 14:08
Your link doesent go to any battery/cell but is generic. Did you mean these? https://www.alibaba.com/product-detail/ ... 2645BUbYCE
Postby expresso » 26 Jan 2021, 17:17
yes thats the company - and the Cell - they were packed very well - each cell totally covered padded - box on the bottom sides top
3 cells in a box - you could have fitted 6 of them if not packed well - so i am happy for that - will start testing for Cap. will take a while with these huge Cells -
Postby sacharlie » 27 Jan 2021, 01:30
Burgerman wrote:Your link doesent go to any battery/cell but is generic. Did you mean these? https://www.alibaba.com/product-detail/ ... 2645BUbYCE
WOW thats just $135/kWh
How much was shipping?
sacharlie
Postby expresso » 27 Jan 2021, 01:37
in my case - i had a better deal because when i found the item - it was free shipping - but after working out the deal i got 9 Cells - one for spare - it was $100 shipping - but that changed during the time i was doing it - they still kept it for my order
this will take a while to charge discharge and recharge - still charging my first one - will let it discharge overnight - and hopefully recharge tomorrow - start on Cell 2 - hoping i get at least 190ah out of it - we see
Postby expresso » 27 Jan 2021, 01:41
if someone wants to take a chance i found some cells for 600 shipped 8 cells 200ah - but hard to get details on them
Varicore - search on aliexpress i am happy with mines - packing - no dents etc, they look pretty new - was told they are new - but we know how that goes - still these are the best so far for me - and easy to work with - no problems messaging back and forth -
Postby expresso » 27 Jan 2021, 01:44
i wonder if they made these cells just a bit wider - to fill my battery tray - lets say 65mm thick instead of 55mm - and keep the rest the same
maybe room to fit more Ah in each cell - 250ah ? as you can see - i have room on the sides
Postby Burgerman » 27 Jan 2021, 12:14
I think 200Ah is adequate!
Postby expresso » 27 Jan 2021, 17:14
yes it is - i havnt used that much even on the 68 mile run - thats with a fast chair - using more battery all the time -
on a slower chair may get even more range out of it - -
Postby terry2 » 12 Feb 2021, 12:10
I had my eye on some EVE 280ah cells for about 4 cells are $480+shipping $90
They are now a really stupid price £1,200 for 8 + £200 shipping. Then you have the new import tax.
And the PL8 V2 has been put back to the end of march.
But there is no point in importing them now to the UK.
Users browsing this forum: LROBBINS and 190 guests
