Burgerman wrote:They are dropping 24v to 5v and its not 100% efficient.
garriew wrote:Hey, I built a few of these USB phone chargers and in about 10-15 minutes the USB end is hot to the touch. What could cause this?
ex-Gooserider wrote:garriew wrote:Hey, I built a few of these USB phone chargers and in about 10-15 minutes the USB end is hot to the touch. What could cause this?
If you have wrapped up the device, it may be getting quite warm inside, and the USB connector is the only heat radiator. If it gets 'hot to the touch' but not 'burn when touched' and the temperature is stable it should be OK, though I'd look at whether there is an easy way to add more cooling. (i.e. heat-sinks, metal enclosures, etc...)
That said, the unit should NOT get hot if you aren't actually using it for power - the amount of power consumed by the input side of the unit when there is no load connected is negligible, so it should NOT get hot if you don't have anything plugged into it - if it is, you need to start looking for problems.
Users browsing this forum: Gnomatic, LROBBINS, sergey0, slomobile and 143 guests
