Burgerman wrote:There isn't a common. Only the volts on each individual cell. Each pin is:
neg0 cell1 cell2 cell3 cell4 cell5 cell6 cell7 cell8
You need a cap across each cell, fed by a resistor, then to the meter. And possibly a diode also in series to drop it from 2.7 to approx. 2.2v so it doesent go off too early.
Yes...neg0 is the common. If you disconnect it everything stops, if you mess up the sequence the cells are not recognised - same with Hyperion.
Generally - what a mess to have to do this alarm damping and shit. Be nice to mention it on the alarm page - you don't just get one of these and whack it in, works perfect. Yes, I know we are experimenting to an extent and this is fairly minor, but I'm ready to drive it and all the wiring is tied up and tucked away, now I have to cut it up again and put in a bunch of other stuff.
I agree, the nicest way is to damp the volt drop so it has to exist for 30? seconds before the alarm goes off. I'd appreciate some guidance from someone on values and connection as electronics was never my strong point. Electrics, yes.
No way are they going in the battery box and, yes, some isolating diodes will probably have to go in so the charger is not messed around, which will drop the alarm volts.
Watt meters:
http://www.hobbyking.com/hobbyking/store/RC_PRODUCT_SEARCH.asp?strSearch=watt%20meterI don't like the idea of inserting these into my 8ga cables. They do use a 'clamp meter' sensor so it might be relocatable.
However, they go to 65Ah. Not enough.
