Everyone has different needs etc. But on my chairs the total weight on the rear drive wheels is 75% approx of the total.
Give or take a small amout depending on what was is possible on each design. (Q700R? run away!)
If its any further forward based they drive like oil tankers, with the rear which does all of the control trying to swing a heavy long front end around sat on small casters. With no traction. That makes the chairs feel unweildy, long, they do not like turning and they feel heavy and hard work indoors. Programming cant fix that.
This is only possible if the casters are wide enough apart, and a centre footplate is used. So that your heels go between the rotating caster fork/wheels as you manoever around. Allowing a
or drill etc to let you shift the seating back.
Downsides, the chair is much more tippy. Well you soon learn this and then reverse up anything steep! If traveling forwards you can easily lift the front as you approach a small curb or whatever so as to climb it easily. Lift the front and allow momentum to crash the rear up. Like a sport manual chair. This takes some skills and needs good throttle control and balance and a proerly programmed chair. Wheelying superbikes up and down the runway and down motorways all day long was useful after all!
Tipping out the rear? Yes I have done that a good few times. I dont like it, but so far its never done any real damage other than embarassement! Hold head forwards...
But thats how you learn how far is too far! Goes right over the anti tips. And what is possible. Its worth it for the shorter chair, ease of steering and indoor lightness of control. Because you use and feel that 100% of the day.
Of course everything is a compromise. So whatever works best for you.
As far as tipping back when lifted high. That CAN be an issue. You dont want to fall out while lifted. But it can be mitigated some my making the lift mechanism move you forwards as it lifts you up.
How? Tilt the whole lift on its mounting so it is 4 or 5 degrees forwards and drill new holes, or use existing options for seat dump angle etc on the base or whatever it takes to do that. Mind over metal right? Then add spacers under the front edge (the forwards bolts) that locate the seat on top of the lift mechanism. Set that angle to whatever your prefered dump angle is.
So now the seat is back to the best place for you when sat normally low. With correct dump angle when tilt is at the low position. In my case 5 to 6 degrees of dump so you dont ride on the tilt mechanism. Thats bad!
As the seat elevator now lifts you up, it moves you forwards an inch or so too. So now its less likely to tip back. But still be CAREFULL!
Everything is a balance, a compromise. After years of experiment I now know EXACTLY what I want to the mm, and in fact have a list of dimentions for seating and control positions written down. Its very long!
And all of this is taken care of on any new chair during the initial proper configuration. That may require a week, a little creative thinking, to achieve.
But it must all happen. A new chair is the STARTING POINT of the chair that you will end up with once set up properly. You must KNOW what you want. And dont stop till you get that. Its just metal. It can be changed and adjusted. Take bull by the horns and
it into shape.
Or the chair will be forever crap! This and 101 other settings and positions needs to be done!
That would (in my case) include a stainless thrust bearing and grease nipple on those casters or replace with proper bearings, as well as stainless caster wheel bearings and correct assembly with adequate grease etc on shafts, bolts, on your chair. Same attention to detail on the rest of that full chair. Replace steel bolts, any place where water goes with stainless allen bolts and grease all of them too. Dielectric grease and so on on wiring/batts and heavy connectors, de-oxit on signal/bus connectors, rebuild swing aways to get rid of play/movement and position correctly, better chargers, and programming. seating and controller positioning, cable routing etc. Ready for use!
You cant make an omelette without breaking a few eggs.
Every stock new chair is assembled badly, configured incorrectly in 100 ways, and needs fully configuring and sorting out. To fit your needs. Then finally programming properly (not 10 mins fumbling by a dealer) before first service use. It can take half a dozen goes to fine tune all that stuff. Delivery quick kick then, or a "fitting" session is not that!
Of course this never happens to 99.9% of chairs, sadly and so they are always mess or at best a compromise that dont work properly. But if you have a few slkills and some patience you can get there!
