First let me say - i have learned alot from this site - and i feel you guys and Burgerman are very knowledgeable for sure - i dont know nothing really about all batteries and connections etc, - and just got interested in all these chargers - etc, in the past few years since i been on this site - which is great -
and no i dont plan on making the connections myself - i am not going to guess anything i dont know enough about - the Tech will be connecting it for me - i just wanted to know for myself - i am curious and like to understand it rather than just hand it to someone to do for me - and still not understand -
in the event its not connected correctly - can anything go wrong with the chair etc, - or would just my direct connection not work - or if connected wrong and i tried to charge it that way without knowing of course - could it be dangerous ?
about the charging specs - i guess i am just as confused as i was at the beginning - i went with the specs i found - maybe my charger i just got is a bit over the top for a True Gel - maybe it will shorten its life - i wont know for sure till i use it and see how long it lasts - now since i am not paying for the batteries - i guess its ok for me to do it and see - but i understand that if i were paying for them myself - it would be in my best interest to get it just right and make it last -
i usually get new batteries each summer - i rarely went two summers with the same set of batteries - and if it does shorten its life - the tech would come - check it - fails load test - i get new batteries - now if i had to pay for them - knowing what i know - i could always buy the AGM style and use the charger for them -
Looking over the spec sheets of those links - and its different from the one i had and different from the battery sticker itself - in that case - yes your right - to keep it at those charge levels - - in my case i am fucked then
i cant win no matter what i do - i tried at least -
but i do get it - and it is very confusing when you hear so many different arguments on the same subject - do i trust the industry - NO - i would take the info from this site first as the correct info over others when i dont know it for a fact myself -
i looked on the battery itself which says the same as the spec sheet i found from MK - 13.8 - 14.6 at 77 degrees F - thats the sticker on the battery itself - again - i followed those specs and ended up with the charger i got - what you are saying makes sense to me and i believe it - they rather you over charge all the time and just buy new batteries - and in the event i had to buy my own batteries for what ever reason - i would just get a MK AGM type or some other good AGM instead of Gel and not worry about it then -
you live and learn
the batteries i am using now are going on the second year and they are not great but also not that bad either - in the summer time - my trips range about 10 to 14 miles - which get me down to the Red each trip - before i am able to charge fully again - so instead of 1000 cycles - or what ever they say - its more like 500 good cycles i would say -
