Burgerman wrote:All of your cells ended together so are a very good set that are all equal. 80Ah out is about what I would expect. If you warmed them to 25C, and discharged to 2.5V you would see 90Ah. But best not to.
Thank you BM (and Shirley). I'm really pleased with how the cells performed, once you had corrected me on my earlier faux pas, a novice mistake.
Moving on...
I hope the other 12 cells are as good, or nearly as good. But they will be what they will be.
For me the best thing about big lithium is I'll be able to go anywhere you like in a day and not have to worry about running out of power or too deeply discharging the cells. Last summer my lead acid used to worry me on longish trips, not only the worry would I get home, but was I ruining the batteries in the process.
