They wont do it however. Because there are a set of settings, and limits, that allow each chair to pass a bunch of tests. For e.g one test is anti tip stability with a test on a slope of X degrees and full forward acceleration***. Allowing you to mess with speed inhibits, forward acceleration on some chairs, motor compensation changes these results. Those are all regulated and tested in the eu and US. braking speeds and run on when stick is released, and more is all legislated too. Its all bollox but they will lock it all down.
Have you obtained and read through the various ANSI/RESNA-ISO documents pertaining to safety / construction etc of mobility vehicles?
NO ... They can occasionally be found via the internet but get removed as soon as the powers that be become aware of the leak ( loss of revenue ).Do you have them?
Thus, they are built around someone that cannot readily shift their weight, but would not know that a weight shift was necessary.
Any seat movement (beyond a small amount of unfortunate unavoidable backlash) would need to backdrive 3 actuators. I described them as being placed radially, but its also part axially, more like a teepee. I can't think a proper name for that arrangement. Those 3 actuators also provide the tilt function, so you are only adding 2. There is a way to make it also do the recline and leg elevate function for no added weight, but that is untested. Height is normal. Battery mass is distributed around perimeter frame with individually repairable cells. Structural 4680 cells if they are ever a real thing. This is necessary because we are occupying the central area where batteries usually set, but perimeter mass works better for the crash structure anyway. As far as speed and wobble goes, expect it to be as fast and stable as a Segway scooter or a racing sim seat. But backlash is a real thing I didn't want to gloss over.
Users browsing this forum: acid_coke, Burgerman, mentado020477 and 39 guests
