Page 1 of 1
Plastic part
PostPosted: 24 Jan 2021, 20:43
by martin007
Hello.
Does anyone know if they sell spare parts for this plastic part?
Re: Plastic part
PostPosted: 24 Jan 2021, 20:49
You are going to need to get your good camera out! I see two blue bumps that look like metal?
Are you talking about the black bits? Are they bushes? Bearings for those parts that lift off?
There are thousands of such parts. You will need to remove one and use that micrometer to find some replacements.
https://www.google.com/search?q=bush+ny ... irefox-b-d
Re: Plastic part
PostPosted: 17 Apr 2021, 22:19
by martin007
It is a piece of hard plastic (PVC) that makes a cushion between the two metal parts.
Something like this...
> https://www.aliexpress.com/item/1005001803582884.html
...but hard plastic; no rubber.
Re: Plastic part
PostPosted: 17 Apr 2021, 23:05
No idea. But you may need to adapt or use something else. Or contact manufacturer.
Re: Plastic part
PostPosted: 17 Apr 2021, 23:17
by martin007
Burgerman wrote:Or contact manufacturer.
I rule it out.
I think is some like this.
> https://www.aliexpress.com/item/32972965953.html
But i only need 4 pieces.
Re: Plastic part
PostPosted: 17 Apr 2021, 23:35
by sacharlie
Maybe search for plastic endcaps or inserts for round tubing.
Re: Plastic part
PostPosted: 17 Apr 2021, 23:50
Search flanged bushing. Or top hat bush. But you need the inner and outer sizes.
Re: Plastic part
PostPosted: 18 Apr 2021, 23:31
by martin007
Thanks all.
I can't find what I was looking for.
I'll leave it for later.
Re: Plastic part
PostPosted: 20 Apr 2021, 02:16
by ex-Gooserider
It isn't clear from the photos whether the part is just a washer like flat disk, or if there is material that also goes on the sides of the pins...
If it's a flat disk, I'd look for a nylon washer that could be press fit over the pin. (might need to get one that was undersize and carefully ream out the hole to fit...)
If it is material on the sides of the pin as well, I'd go with BM's suggestion of searching for flanged bushing. Or top hat bush.
