Problem with Dynamic joystick rem 24 SD
Postby salam321 » 09 Feb 2021, 20:53
Hello, can anybody help me in showing me how to open this joystick to repair it, i tried everything almost
salam321
Re: Problem with Dynamic joystick rem 24 SD
Postby martin007 » 09 Feb 2021, 21:14
Hello salam321
Can you upload a picture?
Postby Burgerman » 09 Feb 2021, 21:23
Theres a screw under the nameplate. Ustick it.
Postby salam321 » 09 Feb 2021, 21:29
There is only 3 screws and i opened them alredy, but still not enough, i though maybe there is somme special technic to open it
Picture coming..!!
salam321
Postby salam321 » 10 Feb 2021, 19:53
Yesssss you were right, 2 screws hidden under the name, thanks man.
salam321
Postby salam321 » 11 Feb 2021, 01:33
Now that i opened it i don't know from where to start, the code signal i get when i try to start the chair is number 1 (first led)
salam321
Postby martin007 » 11 Feb 2021, 01:35
Postby Burgerman » 11 Feb 2021, 01:37
Flat battery? Or if part of a flash code then a defective module. Why have you took it apart?
Postby woodygb » 11 Feb 2021, 02:06
Postby Burgerman » 11 Feb 2021, 07:54
Unplug all the bus cable, reconnect after a little spray switch cleaner. If problem still exists in may be the power module or the seating module.
Postby salam321 » 12 Feb 2021, 17:30
Problem solved, don't know exactly how, but i have doubts about a little wire coming out from inside that might've touched a screw next to it
salam321
Postby Burgerman » 12 Feb 2021, 20:14
Did you repair it? Or are yo guessing? Because the error code did not point to a joystic error.
Postby salam321 » 12 Feb 2021, 22:29
honestly i just opened it, checked it, then closed it again, no reparation at all, before opening it i tried it on another wheelchair and it gave me the same error signal, that's what let me conclude that there is a problem with the joystick not something else.
salam321
Postby salam321 » 11 Mar 2021, 22:48
Nope, still the same problem, it worked only for a while, i had doubts about the joystick cable, since it's damaged arround the 4 pins, but when i used another dynamic joystick rem 24 sd, it worked fine, i don't know what to repair exactly, inside it looks completely fine
salam321
Postby Burgerman » 11 Mar 2021, 23:16
Well at least start with the cable!
Postby salam321 » 12 Mar 2021, 21:56
Bye bye Joystick, i can't use it again even if it works, the trust is gone..
salam321
Postby Burgerman » 12 Mar 2021, 21:59
You are not being logical. Who says anything at all was ever wrong with the joystick? SWAP the CABLE!!!
Postby salam321 » 14 Apr 2021, 23:25
HELLO
TODAY I LOST THE SECOND JOYSTICK, ALMOST SAME WAY AS I LOST THE FIRST ONE, ONLY IT WAS MOUNTED ON AN OTHER WHEELCHAIR
I DON'T KNOW FROM WHERE DOES IT COME FROM, I AM HAVING DOUBTS THAT THE PROBLEM IS RELATED TO OTHER PARTS..DX MODULE OR THE BATTERIES MAYBE
salam321
Postby Burgerman » 14 Apr 2021, 23:43
Did you replace the bus cable(s)?
You are doing illogical things. That will never work. If it does by some miracle then you wont kow WHY it worked.
What does LOST mean?
Postby salam321 » 15 Apr 2021, 00:04
LOST MEANS DOSN'T WORK AT ALL, NO POWER, I DIDN'T REPLACE THE BUS CABLE, ALWAYS THE SAME, I REPLACED THE DAMAGED JOYSTICK WITH ANOTHER ONE AND IT WORKED, I AM NOT DOING ANYTHING ILLOGICAL, WHAT'S HAPPENING IS ILLOGICAL
salam321
Postby Burgerman » 15 Apr 2021, 01:49
You have kept the faulty bus cable. So we now dont know where the intermittent fault is. So finding the problem is now impossible. Thats illogical. A cable is usually an intermittent fault. So must be removed and replaced. And then all your joysticks might not be "faulty"...
THIS is why:
Postby salam321 » 20 Apr 2021, 03:49
hi everyone,
i guess there is some tools for diagnostics for such cases, something that allows you to read the memory card of the joystick and tells you what sort of error has occured
salam321
Postby Burgerman » 20 Apr 2021, 04:03
Yes. But first swap bus cable. Or that wont work properly either.
Postby salam321 » 21 Apr 2021, 06:46
Done, what's next ?
salam321
Postby Burgerman » 21 Apr 2021, 06:48
Are you sure? Is the problem still there?
Next you need a cable from woodygb viewtopic.php?f=1&t=5488
or make your own so you can connect an oem level programmer. PM me.
Users browsing this forum: No registered users and 84 guests
