i have black tires here - they seem smaller than these - for some reason these seem larger than my others that all show same size 280-250-4 -
maybe i should get a pair of those you used in case when i move it back the seating - if it dosnt fit with the tires i have - can use the smaller ones they may not touch being i would be in a little tilt also -
recline feels great though - i will use the stock tires in black once i get them for now - but i was thinking of adding in the street tires i have but not as wide -this time - not sure cant decide yet
but those same tires in the front - cant find them no where in black -
Arima wrote:Hey good for you expresso! You fought the fight and won. I'm sure you will figure out the tires.
Burgerman wrote:You want these:
Fusiongoat wrote:Maybe these https://maverickmowersupply.com/160001- ... ooth-4-ply
Those were the only decent ones I could find in that size. Anyway, glad you got it.
Burgerman wrote:Is what the name? And which chair?
Expressos NEW chair is a sunrise medical Quickie 62x something. Or 64x something. My chair, same company, Q700r. Different options different countries.
Chair is 636 - i added features and Rnet 120 8.5 motors etc, - we have that same chair here now also - its called i think 500R - the anti tippers are on the ground all times - is that how your chair is also ?
Burgerman wrote:Chair is 636 - i added features and Rnet 120 8.5 motors etc, - we have that same chair here now also - its called i think 500R - the anti tippers are on the ground all times - is that how your chair is also ?
No! THAT would drive me mental having those things stuck out behind me.
The chairs you have are the 500 spec ones, and its a Q500H which is Hybrid. Rear casters on the ground like mid drive. Dont think you actually have the rear drive version over there? Maybe not here I will look.
We have the Q500 too. In mid, centre, and proper rear drive with no casters on the deck. At least I think so.
My chair is a little different. Its the Q700R. It has no rear casters, just elevated anti tips. The 700 is a bit higher spec, but quite similar. Slightly better front/rear suspension. Slightly longer wheelbase too I think. Can be Front or Mid or Rear drive.
Is this name that chair?
In the UK we have the Q500R rear drive.
https://www.sunrisemedical.co.uk/q500r
And loads of options like a power centre footplate and all the rest.
And the Q700R too. Like mine...
https://www.sunrisemedical.co.uk/powere ... -sedeo-pro
And another version with more expensive seating... And a Q100R Q200R, a Q300 and 400, and 500... And obviously the 700.
i have enough tubes here - i will double check - last time i checked - i had a box full of tubes - different sizes - since all my chairs use them now -
i have to plug in the programmer soon to check if i can speed up the seat lift - its not fast going up or down - dont need it super fast but a bit more would be good -
with the programmer i can check if i have a PM 120A ? if it allows me to set it to 120A - means i have it ?
i dont trust them any more - the manufactor sunrise rep etc,
Users browsing this forum: No registered users and 367 guests
