i had to go slow since my girl was walking my other chair back also -
Burgerman wrote:So if it goes wrong or you want to modify it with different motors, or seating, no problem then as it yours? Maybe sell it? Or swap it for a different chair? You can do any of this as the owner because its yours? If not it isnt yours. How does this work?
If it is yours you could sell it unused as new. And buy 2 like mine, for 4.4k each from the UK!
Years ago I bought a new ford with a 4 cylinder engine. I threw that away with its gearbox, prop shaft and rear axle and replaced it with a blueprinted alloy V8 and 5 speed manual box from a completely different manufacturer. Because I could! Because it was mine.
Yes I know you dont want to do any of this. Its a hypothetical question. Can you? Because technically a NHS supplied chair still belongs to the NHS. And they freak out if I start hacksawing the swing away footrest mounts off for e.g... Tested! They were running around like nutters trying to get me to sign disclaimers etc.
Burgerman wrote:Is what the name? And which chair?
Expressos NEW chair is a sunrise medical Quickie 62x something. Or 64x something. My chair, same company, Q700r. Different options different countries.
Burgerman wrote:I had this discussion about lithium batts years ago. They said that if a normal user wore out lots of motors (and I do!) that they would likely blame the lithium battery as it means I could go much more distance every day. And that there may be some disagreements about replacing worn parts like tyres, motors etc.
Fortunately I am on a different scheme. They just write me a cheque every 3 years and I do my own thing. But it seems others are not as persuasive! This system should now be open to all. But they are fighting it! The communist NHS block dont like change!
Expresso's "NEW" 636 is not even close to your new chairs BM, it is essentially the same design as the F-55, except the frame is made from aluminum instead of steel and the front cross tube is more of a "V" profile where the F-55 is a flat bottomed "U" which makes it impossible to do a BM2 style modification... Since it's aluminum it is also harder to do the BM-3 style because of the issues with welding aluminum....
The swingarms and motors are different from the F-55, but basically the same 'swinging motor' style rear suspension, and no front suspension other than possibly a shock absorbing caster fork....
The Q500's and 700's (as far as I know, RWD versions are not available in the US) are more modern and have suspension on both the front and rear ends....
This is why I keep saying that if wanting a GOOD RWD chair, a US (Or Canadian AFAIK) resident needs to order it from an EU / UK source, and fly over to pick it up....
expresso wrote:my Chair is from Sunrise Medical
quickie 636 -- the seating is from Motion Concepts - where are you from ? USA ?
what is your insurance ? Medicare - Medicaid ?
https://www.sunrisemedical.com/
Users browsing this forum: Scragger7 and 19 guests
