You can look up the specs, if you know the make and model of the valve.Just today I was replacing one of the Dynamco air valves
Burgerman wrote:Take the broken fitting to your local pneumatics specialist on your nearest dock, industrial estate etc, and let him give you the correct part. He will id it by eye in seconds.
This is a push on 4mm fitting, yes they work reliably! and an 1/8th male BSPT thread. Other sizes are available. https://www.bearingboys.co.uk/Male-Tape ... tud-3859-p
90 degree version https://www.bearingboys.co.uk/Male-Stud ... bow-3943-p
4mm to 1/4 https://www.bearingboys.co.uk/Male-Stud ... ud--3836-p
Etc. Also in 4mm tube to male m5 m5 and m7 and m8...
woodygb wrote:You can look up the specs, if you know the make and model of the valve.Just today I was replacing one of the Dynamco air valves
http://dynamco.com/index.html
Burgerman wrote:Will be a pipe thread. In the UK it would be bspt. And 1/8th or 1/4 or whatever. If old. Or metric if modern.
In the US no idea!
Post a clear picture.
Users browsing this forum: acid_coke, daveonwheels, shirley_hkg and 80 guests
