Burgerman wrote:Yes 3. It was 1.75. Why? Because the rim doesent split in the centre. And the part I added INCLUDED the outer rims lip that I had removed. I really wanted another half inch width.
our rim stock was 1.75 wide - not a two part rim ?
how did you remove the outer lip on that - in my case - i will use a tube - so needs to be smooth
did you smooth it down - how - if its too much to do - no one will want to do it for me
Burgerman wrote:I took a JIVE wheel apart and used the REAR part next to the chair/motor. Thats the side that unbolts.
I cut off with a jigsaw the lip that holds the tyre on... Thats the silver ring.
Then I smoothed it off with a sanding disk in a drill... And sprayed it black. Thats the black ring...
Burgerman wrote:No unfortunately.
