expresso wrote:Use the chair first for some time and see how you feel - you may not need to swap anything - it wont be cheap if you did go down that road
you can find many Rnet parts online - ebay etc, - but not sure its worth all that trouble IF your are ok with the setup -
i like to hear how it works with that linx - have you used it yet - ? Rnet does give you alot of options to adjust - you have more adjustments you can make on yours than i have with mines and i got used to mines enough that it dosnt bother me -
that maybe the case with your also - you may just be fine that way it is - or with some adjustments you can make - use it the whole summer and see if anything bothers you enough to want to change it - you may not want to after some use -
Your right I have it dialed in an only the slow speed while tilting is only thing I would like to change but cant But that's really no biggy. Its something I may consider down the road. But the bounder and controls are great I can romp the hell out of this chair and no worries I love it. I didn't get the linx gyro module because I didn't want the corrections from it and its 1000$ bucks lol but I'd like to know if anyone else has a linx gyro module
