Agreed....Burgerman wrote:I cant. Dont think anyone this side of the atlantic can. Thats not a controller that we ever had here.
Search your SD card for file and reload. If no, go through the entire setup again and save it.
Select GB - CWD for TDX.
No big deal .
fishinjunky wrote:Unfortunately if you didn't save your settings to the card or a computer previously they are most likely lost. You will need a Pro sd card to redo your settings and then load them to the chair. I have the pro card files if you need them.
Here's a video of a guy programing a mk6i
https://youtu.be/ycIWIUyzrKY
FelipeOliveira wrote:fishinjunky wrote:Unfortunately if you didn't save your settings to the card or a computer previously they are most likely lost. You will need a Pro sd card to redo your settings and then load them to the chair. I have the pro card files if you need them.
Good morning, if you can send me the files you have, at least if the controller accepts it, then I'll be able to move on, racking my brain!!! Taking advantage of where I find the SD PRO, for sale? I am from Brazil ,
fishinjunky wrote:FelipeOliveira wrote:fishinjunky wrote:Unfortunately if you didn't save your settings to the card or a computer previously they are most likely lost. You will need a Pro sd card to redo your settings and then load them to the chair. I have the pro card files if you need them.
With the PRO files I send you. You won't need the PRO sd card. You only need the sd card you have now to place the PRO files onto it making it a PRO SD card. Then unzip the files on the card and open the programing software once you have everything programmed hit save not save as this is described in the video. Then take the card put it in your chair and read it to the chair. The video shows how except you wont need to read from chair to card becouse you are starting from scratch. But first make the PRO SD card with the files I send then follow that video except the first step. You'll start will plunging the PRO SD card you make into your computer
fishinjunky wrote:
I need your email to send the files to
fishinjunky wrote:Ok I emailed you the PRO SD files
Check your messages.
thank you woody
I also helped by being positive.
For the usual attention
Users browsing this forum: Mr.Math, shirley_hkg and 101 guests
