expresso wrote: i normally ride alone and take long rides - i normally make it home after 40 miles give or take and my JS showing a number 5 -
the total trip was 42 miles which i do easy on my own the way i ride - but this day - my JS numbers are running lower and started flashing at number 3 - thats never happened before - unless the time when i did 68 miles - so i knew i used alot more battery this time then ever before -
Burgerman wrote:But thats the problem. You do not know. Thats the one thing you must know. You only know the total of 8S cells. As you get towards the end of your x Ah one cell will drop like a rock and the rest will be fine. And you cannot see that. And if theres any imbalance developing you cant know. And this is the thing that will kill off a cell. You only do it once and thats it. It would pay you to get a cell monitor if you are going long distances that use up lots of the pack. They are cheap.
Victron are adding an option to watch each cell in a update soon.
Burgerman wrote:I use one of these. I dont plug it in unless I already went about half range. https://www.youtube.com/watch?v=UIYCKYfNkiE
All you need to know. And cheap from bangood etc.
hobie1dog wrote:The new narcotic pain patch they have me on now is finally allowing me to sit for 6-7 hours in my chair. I'm not a fan of it as it leaves me lifeless, it removes all enthusiasm for life. I just found a good source of edibles, so I'll then be able to quit taking 6 pills a day and get this patch off, and get to feeling some good sensations in my body again.
Users browsing this forum: acid_coke, mentado020477, rover220, Scollard, woodygb and 37 guests
