I finally got a flat - i noticed my tire had some slime coming out - so thats a done deal - i wasnt out when i noticed it - but went out local anyway to do a few things and back home - at home i heard air coming out along with the slime i guess trying to seal it - but didnt really work
at least it holds on for a bit - i am not surprised - the tires were worn out smooth - - i have to change them more often if i use this chair more to be safer - which i will do
i was wondering - one tire had the flat - one is fine - tube wise that i know of - i will change both tires - should i change both tubes also or just the one tube that is flat ?
what are your thoughts on using the same tube ? or just change both to be safe or safer ?
heres a good example of never having enough chairs - i even just gave away my first chair - shipped overseas to someone who has nothing and no legs - so he will be happy to get it - free - i gave cushions - chargers - etc, armpads - i hope it makes it there
i have now only 4 chairs - One i use indoor only and for Doc. - denist visits since its compact P222se - i love it indoors - dosnt work well outdoors - seat back not good enough now - no support etc, but works fine looks brand new still -
this chair i still have lead with 60ah add on - dont use it to ride at all -
my new chair needs seating to be adjusted - remove center plate - etc, not using it - not comfortable the way it is - waiting for the parts to fix it - bounder now has a flat - cant use
leaves me my older 646se - only 105ah pack inside headways - have to use ADD On with this chair -
goes to show - even 4 chairs and you can get stuck - when two chairs are down for repairs - - one not really good outdoors - cant go far etc,
rule that out - only one last chair i can use outdoors for long rides - and if that goes down - for some reason - i be stuck -
4 chairs and close to be stuck at home - if i had more room - i would get another chair also - cant have enough chairs or enough lithium
