by ex-Gooserider » 13 Jul 2021, 02:21
On my Jazzy, the freewheel lever disconnects the gearbox, so the motor and brakes work just fine, but you don't get any drive... Since the motors run, there is no 'error condition' to throw an error code, you just don't move.... I actually think this is a MUCH better design than the ones that just pry the brakes open, as the reason one usually puts a chair in freewheel is so it can be moved w/o power... When the gearbox is disconnected you are basically just turning the axle, so just bearing drag and the grease in the gearbox for resistance, and it is pretty easy to move the chair.... (Downside is it doesn't take much of a slope to have a roll-away...) W/ the brake release, you are having to back-drive the motor and gearbox, so it is MUCH harder to move the chair, so somewhat defeats the purpose of the free-wheel lever.
