Hi guys,
I haven't needed the scooter for a while. Not entirely sure of the current pair of batteries, so thinking again about changes.
I have two 12v18Ah. SLA. It's a size constraint.
I have an old fashioned charger. A slow one. Nobody ever addressed what happens if I charge continually (on float) with the batteries installed in an old fashioned scooter made before float.
I have an out of use 8Ah modern charger. Could I use it? Either through the scooter or separately if I do some rewiring. Getting hold of the components can be tricky. Might need to switch to different contacts. I did extensive research on that last time.
I watched a video on combining Lifepo4 and lead for a sailboat solar system. He said the critical part was combining the two, so I should probably keep them together permanently if I do that. Do I charge continually the lead or the Lifepo4 batteries? He had a solar system, so that question wasn't fully addressed. What would be the ideal size in Ah? I'm thinking it should be lower than the SLA and probably two of them attached in parallell.
My thinking is that the gauge on the scooter will reflect the voltage of the SLA batteries, so I don't really need to monitor the voltage of the Lifepo4. By the time I lose a bar, those will be depleted, so I really need to watch the bars.
