I use the Dahl wheelchair restraint. If I got a Permobil M3 would It work with my current Dahl system?
Burgerman wrote:What the h is a piko switch?
Cant you just set the presets in the programming?
Re: Programming the Quickie Q700 Ergo seating
Postby Burgerman » 19 Aug 2021, 20:17
This is how easy it is to swap a battery.
https://www.sunrisedice.com/asset-bank/ ... /43539.pdf
Page 24. Theres no need to take apart anything at all. The whole top plate (with the seat still on it) lifts like a lid. Or a car bonnet. 20 mins max at your home. So no idea why anyone would want to take it away.
Frank wrote:This is how easy it is to swap a battery.
Hello,
We tried to have access of the Quickie 700R batteries by releasing the two handle screws under the front of the seat frame that connect the seat frame with the seat module interface. My wheelchair is equipped with lift, tilt and elevate. Then with we tried to flip back the whole seat, we tried to lift it upwards from the center foot plates but it was extremely heavy, one man could not lift it. Should it be that heavy or are we doing something wrong?
Thank you in advance for your help.
Users browsing this forum: acid_coke, Bing [Bot], martin007, mentado020477, shirley_hkg and 42 guests
