reply to your response to my request
Postby cositom » 02 Sep 2021, 11:37
every body whom have assisted me in my endeavours, big thank-you, how ever though i dont wish to go over old ground programming and stuff but i have matter that relates, as i said this is all very new to myself, I have been unwell for a while but now back to it, lol ingot leads and all that thanks woody, how ever i since found on my you-q alex FWD, it appears i could be wrong i fitted a new but second hand controller off ebay, but error code suggested software conflict incompatible, not sure whats happened since then since connecting my programmer shows no software on the system, hence now where I am stuck, i got my other chair perimeters sorted you-q alex no luck i believe chair is 2010 about, as i purchased as a none runner how ever not realising how complicated these appliances truly are, please any thoughts advice is truly welcomed, I can-not at moment meet the cost of new chair until my mobility assistance gets reinstated,
cositom
Re: reply to your response to my request
Postby Burgerman » 02 Sep 2021, 12:34
No idea what you are trying to do.
Lets start from the beginning. No rambling. The occasional full stop. Accurate information.
So.
1. What is the chair? Seating options and module?
2. What in the power module EXACTLY?
3. What is the joystick exactly?
4. why exactly did you change it?
DETAILS matter.
And what happens when you connect the programmer? And WHICH programmer?
What is mobility assistance?
Postby cositom » 02 Sep 2021, 16:26
o.
1. What is the chair? Seating options and module? https://photos.google.com/photo/AF1QipM ... eqbVIhjBVi
2. What in the power module EXACTLY? dynamic dx2
Invacare® REM A/B Remote
4. why exactly did you change it? previous controller burnt board in controller module
tis best i can give thank-you
cositom
Postby Burgerman » 02 Sep 2021, 16:56
1. you keep linking to an advertising company sign in page. I have no google account and woudnt want one. I want text. What chair is it and what functions?
2. OK
3.  ??? Invacare® REM A/B Remote
What does that mean? Is it a DX24, REM550, ETC? Which?
Whats a controller module?
Joystick or power module? And did you replace like with like?
Where did you get your programming settings from?
Postby Burgerman » 02 Sep 2021, 22:26
If you can expain exactly what motors (to allow the motor compensation to be set safely and brake voltages) and what power module (120A DX2?) and exactly WHICH joystick module, if it has a seating module and which one, and what seating functions it has if any, then someone may have a similar chair. And could upload THEIR setting file. So that you can load something that works on your chair. And then you can modify the settings to suit you personal needs/chair.
Postby steves1977uk » 02 Sep 2021, 22:53
That Google Photos link just leads to a 404 page if you sign in. :fencing And why bother when you can upload photos in this forum?
Here's what I get...
Postby cositom » 02 Sep 2021, 23:17
1. you keep linking to an advertising company sign in page. I have no google account and woudnt want one. I want text. What chair is it and what functions? YOU-Q alex 2013 FWD
2. OK
3. What does that mean? Is it a DX24, REM550, ETC? Which? DX2 REM 420/421
Whats a controller module? the unit thats under the seat i would call it main CPU control box unit dx2 dynamic
And did you replace like with like? yes like for like
Where did you get your programming settings from? no setting thats the issue no software is found by r-net program to make settings
cositom
Postby steves1977uk » 02 Sep 2021, 23:30
Tom,
R-Net is a completely different system to the Dynamics one. Don't tell me you tried to write a R-net settings file to a Dynamic joystick/PM? Anyway it wouldn't allow it to be written.
What programming software are you using? For Dynamics you need the Wizard program.
Postby cositom » 02 Sep 2021, 23:53
i got wizard 5 and 6 i believe the issue could be that laptop is running a much newer version than needed, all this is new stuff to me, i got r net on another chair just a mix up thats all
, im going to hunt down one of my old lap tops that has xp on it and try that
cositom
Postby cositom » 02 Sep 2021, 23:56
thank you burgerman, i get that info tomorrow too late now will update ASAP
cositom
Postby Burgerman » 03 Sep 2021, 00:01
You will need the DYNAMIC Wizard software to program the chair. Either one.
Postby LROBBINS » 03 Sep 2021, 08:15
Note that in Dynamic systems most of the program code is in the joystick module (or other remote). The power module has only stuff that is directly relevant to power management. P&G does the opposite.
Postby cositom » 19 Sep 2021, 00:30
im unable to establish drive motor details, i have discovered the control module is corrupted, not sure what to do now advice please, thank-you in advance
cositom
Postby Burgerman » 19 Sep 2021, 01:53
We need to know what chair it is.
Postby cositom » 20 Sep 2021, 10:32
YOU -Q Alex full rise and tilt seat, no lighting 2013 when carer gets here i find out more info on chair tag FWD
cositom
Postby steves1977uk » 20 Sep 2021, 11:21
Corruption seems to be mentioned quite a bit on Dynamic setups. What causes the settings to become unreadable by the joystick?
Never had a Pilot+ or R-Net PM settings become corrupted, not saying it can't happen, just that I've never experienced it in 33 years of using Penny & Giles setups.
Postby LROBBINS » 20 Sep 2021, 12:47
Rachi used a Dynamic DX [PM90 + SpecialtyControlsRemote + Attendant Joystick + CLAM] every day for about 20 years (until going to my own CANbus+Roboteq setup). She NEVER experienced any corruption.
Postby Burgerman » 20 Sep 2021, 12:56
Not much experience with dynamic. But what I had, no corruption. I just didnt like it for many reasons. I suspect its a user issue.
Postby cositom » 20 Sep 2021, 17:19
regardless tis wizard 6 is telling, i do more research suspect i have to break it for parts i look for other controller
thanx for alls input
cositom
Postby Burgerman » 20 Sep 2021, 19:04
You dont want 6. You want 5 and then have better access levels.
Postby LROBBINS » 20 Sep 2021, 20:19
Wizard 6 also cannot work at all with some older modules, such as the Specialty Controls Remote.
Postby Seajays » 20 Sep 2021, 23:09
I have a Wizard 5
Seajays
Postby cositom » 21 Sep 2021, 12:22
Burgerman wrote:You dont want 6. You want 5 and then have better access levels.
i give that a go thank-you
cositom
Users browsing this forum: No registered users and 87 guests
