I know the motors are 700 watt vs 800 in the v6
Depending of the area where you'll hike with your X8, my opinion is, it's better to speak in hours rather than miles for the endurance.
Burgerman wrote:....
Its also a scooter really, so uses very little power (current in amps) to turn in comparison to a normal powerchair. Those even waste huge currents just keeping straight. And so you would get more range per Ah used than a powerchair as scooters almost always do. But 4 motors ruins that gain...
You're not right.
Turning with the X8, needs power/amps/volts.
''While rolling your front axle stops you needing to correct in the same way on a sideways slope of road camber.''
Absolutely ... NO.
While rolling on a rounded road or track, my front axle wants to go down the hill. So I need to correct heading.
And more than that, when there is a small hole, or bump, the X8 front wheels turn without any joystick movement. And you need, every time, except on a road like mirror, to correct heading, again.
And when traveling along a lateral slope, a powerchair tries to fall to the low side. In order to travel along in a straight line the lower motor has to rovide all the thrust, and the high motor actually has to provide NEGATIVE power to prevent the chair turning and running down to the curb. Because the CG is well ahead of the drive/steer wheels and the caster is free to rotate and go toward the low side.
swalker wrote:.... Because the X8 sends roughly equal power to both the front and back wheels on a given side ....
Users browsing this forum: No registered users and 154 guests
