Charging
Re: Charging
Postby Burgerman » 13 Sep 2021, 11:25
See this?
It takes hundreds of amps to start a vans diesel engine. Thats why it needs a minimum 480A cranking amp rating on the battery according to the vans manufacturer. This one belongs to one of my carers. It had its lights left on all nght and is a winter morning. I jumped it with my chair. So again it takes hundreds of amps to both pull up the dead battery and additionally to start the engine on top. In the past I have measured similar operations and its a strong 200+A to crank in summer. Hell the heater plugs alone take 35A!
But 50A anderson not even warm. And theres 4 here! 100A fuse in loom, no problem. Because the high cranking current does not last long enough to blow the fuse either...
http://www.wheelchairdriver.com/gopro/starter.mp4
Re: Charging
Postby davidpaul » 13 Sep 2021, 15:52
Are the automotive crimp type spade connecter still the only option for plugging in to the control module ?
davidpaul
Re: Charging
Postby Burgerman » 13 Sep 2021, 22:00
Or ebay for a battery loom.
Re: Charging
Postby Fred005 » 15 Sep 2021, 08:30
Hi.
Supposing a LiFePo4 configuration with a good charger wich will make a right cells balance.
Without the use of any BMS, how could I have an automatic switch off of my main power when 1, or more but at least 1 cell voltage will reach to the low voltage setting ?
Thanks.
Fred005
Re: Charging
Postby woodygb » 15 Sep 2021, 08:50
You could purchase a battery monitor with an audible alarm...this would warn you when the cell / cells are approaching a voltage cut off point.
The following is an EXAMPLE ...NOT A RECOMMENDATION.
https://www.ebay.co.uk/itm/323150448067 ... 4d88e9f2a3
Re: Charging
Postby Fred005 » 15 Sep 2021, 09:22
I had that in mind. It's a good idea.
However, if possible, I'll prefer an automatic switch off, as a BMS can do.
Why ?
Because of, most of the time when I'm hiking with my X8, it's I need 100% or so concentration about the track where I'm.
Very very often, on my left or right (sometime left and right) there is a huge precipice, and watching a monitor is not safe a bit.
Ok you'll say me if the main power will switch off in this kind of place, I'll have to manage some big problems. You're right. But if I can save my cells it's 1 problem solved.
So, it's why an auto switch off will be welcome for me/my need.
Fred005
Re: Charging
Postby woodygb » 15 Sep 2021, 10:29
The AUDIBLE alarm removes the need for you to watch a monitor and could be set to warn you when approaching the cut off limit...thus you should have plenty of time, to make an informed decision about what you should do next.
Re: Charging
Postby Fred005 » 15 Sep 2021, 10:43
Yes, I ubderstand you.
However no solution for an auto switch off ... ?
If an audible/visual alarm can be powered on, it could be possible to send information to a power relay, no ?
Fred005
Re: Charging
Postby woodygb » 15 Sep 2021, 11:08
Fred005 wrote:Yes, I ubderstand you.
Yes ...The signal from the alarm could be recognised by an Arduino or similar device ... you could even program in a pre-determined delay ...and then action would be taken to turn ON/OFF a suitable sized contactor.
Re: Charging
Postby shirley_hkg » 15 Sep 2021, 13:39
① Those cell monitors drain the first two cells , so will mess up the pack.
② Your worry seems unnecessary if you had a pack large enough , like most of us did here.
③ Install a £25 adjustable BMS instead , to power a contactor that controls the main output.
④ Avoid to output via BMS directly , and be able to flip the contactor manually to continue in case of emergency.
Re: Charging
Postby Fred005 » 15 Sep 2021, 14:31
shirley_hkg wrote:① Those cell monitors drain the first two cells , so will mess up the pack. Thanks for this important information.
② Your worry seems unnecessary if you had a pack large enough , like most of us did here.My worry is not unnecessary, believe me. I never know how long will my hike be, because of many uncontroled parameters.
③ Install a £25 adjustable BMS instead , to power a contactor that controls the main output.That is what I need, EXACTELY ! Do you think to one BMS or do you have links, please ?
④ Avoid to output via BMS directly , and be able to flip the contactor manually to continue in case of emergency.It could be a good idea. A very good one.
Thanks for your help
Fred005
Re: Charging
Postby shirley_hkg » 15 Sep 2021, 14:42
Re: Charging
Postby Fred005 » 15 Sep 2021, 15:35
Thanks for the photo.
If you have a link about the BMS you were speaking, it'll be fine.
Fred005
Users browsing this forum: LROBBINS, martin007, Raro, steves1977uk, woodygb and 119 guests
