Burgerman wrote:https://images-na.ssl-images-amazon.com/images/I/41619TpniKL.jpg
Rower's use these.
Spectra_Pilot wrote:Burgerman wrote:https://images-na.ssl-images-amazon.com/images/I/41619TpniKL.jpg
Rower's use these.
Thanks for the replies but honestly, the cap mirror is a joke, tried, tested, binned months ago. Now I'm sure I'm not the only powerchair user with zero head/neck movement that struggles manoeuvring in tight spaces (rooms/doorways/public transport etc etc)
I just fail to see how something so logically simple as a 'reverse sensor' is made out to be as difficult as getting a wheelchair to the moon!!
I thought we all had a positive 'can do' attitude to life with its multitude of individual personal daily life challenges, helping others and offering advice and support to others in need, life's journey. Obviously I'm in the minority
Spectra_Pilot wrote: Hi everyone, I'd just like to throw this out there - has anyone tried/tested/is using a wheelchair obstacle/hazard sensor for reversing nto tight spots? It would be fitted to a new Invacare Aviva (privately).
I'm totally rigid with zero neck movement before anyone says 'look over your shoulder
I know we're a million miles away from having one on something like the LYNX REM400/500 display.
I'm not bothered by seeing behind as I can plug in a USB camera, but that's a faff and I need to hold my mobile all the time. Some sort of noise alarm, such as a car beep......beep.....beeeeeeep to warn of obstacles!
All opinions/thoughts & suggestions will be greatly appreciated.
martin007 wrote:In that case the best is a rear view camera.
greybeard wrote:This doesn't really answer Spectra-Pilot's question.
greybeard wrote:I tried a few motorcycle rear view kits for when I was forced to use our rural roadways, but ran into mounting problems for the screen. In practice the screens were all too small to be seen easily and they also gave a true image, ie not giving a mirror eye view, which was confusing.
Spectra_Pilot wrote:wheelchair obstacle/hazard sensor for reversing nto tight spots? It would be fitted to a new Invacare Aviva
Rollin Positive wrote:I would figure a better mount of the monitor like a flip up at the end of the joystick, plus figure a way like to use the monitor to stream content or app access
slomobile wrote:Rollin Positive wrote:I would figure a better mount of the monitor like a flip up at the end of the joystick, plus figure a way like to use the monitor to stream content or app access
Great idea. Instead of a standalone screen, mount your phone there at the end of the joystick. Plug a rear facing USB camera into the phone OTG port. You can even view behind without adding a camera. Switch to selfie mode and swing out the joystick pod to see around your shoulder.
Rollin Positive wrote:BM has a cool mount for his switch box I would love to see a 2nd screen set up like his switch mount but on the joystick side
slomobile wrote:
What should it do when it encounters an obstacle? Pick as many numbers as you want and only one letter.
1. Alert you audibly.
C) Alert and provide cues for you to navigate around the obstacle. Cues provided via your numbered selection(s).
If these options don't capture what you want, please describe what you want.
What model chair is it? INVACARE AVIVA RX 20 MODULITE (with LINX REM 400 CONTROLS)
What part of the chair usually hits obstacles? Casters, seating, other...
What obstacles are you trying to avoid? SEE above
Describe the scene where you encounter these obstacles. I'm a 24/7 powerchair user, physically rigid (like a mannequin (Google FOP)) and struggle manoeuvring between rooms, in busy places, public transport etc etc.
Luci is a finished product shipping right now that provides a B level of function. There are lots of video testimonials for Luci.
If you want something different, I'm happy to help you find or build it. I need something different, and am working on it. I would prefer to include more than just my own preferences.
I've asked about this type of device on this forum before and was met with only opposition.
It's all very well to keep adding powered gadgets to powerchairs, but what do most people complain about??? Lack of RANGE and dead batteries!
Users browsing this forum: phoenix, rover220, shirley_hkg and 37 guests
