Wow, thanks, Woody, looks like you're right. It's hard enough to determine the type of gearbox because they look alike.
Based on the video, the gearbox design looks quite simple and will probably be more reliable and easier to maintain.
The only problem is that it is not easy to get these motors everywhere, because they are rarely used.
slomobile wrote:These motors are back to back. There are small potential for EMI issues with having the commutators close to each other.
Notice the motors have a larger diameter than typical powerchair motors. The rotor is further from motor centerline, a longer effective lever, so all else being the same you get more torque at less RPM. That means a smaller gear reduction ratio for equivalent chair speed. Planetary gears share the torque through several planet gears so they are stronger, but heavier. But things aren't equal. These motors are shorter. So there is less motive force for the same winding resistance. Its hard to say how this will compare to 300w motors.
Thank you for the information. You're right that the lever for the brake doesn't look accessible at all, but maybe it's potentially a good idea.
duke1 wrote:it looks a solid build but no surprise ime russians build stuff to last a long time
Unfortunately, nothing good is being done in Russia right now except vodka and depression.
It's a powerchair made of ordinary Chinese parts, just like everywhere else.
