If you drive up a hill the chairs speed is slower than the display. If you drive downhill its faster than shown.
If you drive up to a wall and try to push the wall. The speed simply shows your joystick position. 6MPH CHAIR? It will show 6mph even though you are not moving.
''Try the wall...''
And I brake my 2 fuc..ing feet ...
Not necessary to do with a wall, as I said U, try a 45° climb, and if you can, you'll see your JS full forwoard but your speed not a lot.
If you try with this 45° climb, your feet will stay safe.
Did U read me BTW ?
NO
''My, and many, GPS, is really very acurate, for the speed. And why ? I've a sensor on a wheel counting wheel rotation.''
Re: How do chairs know their speed?
OMG ...
''GPS has nothing to do with wheel sensors''
Well ... today, I mean in '21, GPS means both the Global Positioning System, AND the device.
So when I'm speaking of my GPS it's my Garmin, as I wrote many time.
My Garmin can work, for the speed not position or altitude but I thought you know that, with GPS satellites or, if too obstacles are providing a bad reception, with a speed sensor (visit Garmin, for exemple, web site....).
@biscuit:Fred do you have an RPM counter on a wheel shaft? I assumed that would not work for a wheelchair because it has left and right wheels.
I can't see any way for it to deal with anything other than going straight forwards.
Yes, I've this:
https://buy.garmin.com/fr-FR/FR/p/pn/010-12843-00
And yes it's working fine.
You could be ''right'' if I was only doing ''donuts'' during many hours.
But during my hikes, one time I go straight, an other I turn left, or right.
Width of X8 is 70cm, so even doing donuts will give a small error.
In any cases all what I'm saying have been checked with, for exemple a friend hiking with me (but ... He's wearing is GPS watch always on the left arm, so ... ''I can't see any way for it to deal with anything other than going straight forwards.'' Lol !
Or other friends with a mountain bike, or cheking with topo maps.
In 1 word I don't have tons of electronic device at home, as some here, but at home I'm not often.
On the other hand, on the field, yes I'm. And when, again and again, when I'm climbing a hill, whatever it's slope, when my JS is full forwoard, I never see the same speed, depending of the slope.
After, you can think what you want, no problem.
I was just giving my ''knowledge''.
So, what you mean is, whatever the slope, it's the joystick position who will indicate the speed.
Ok. If you say that ....
So for the distance it's the same .... Logical ... for you.
It drives by pulse modulation . Does it know the rpm of the motors ?
So the question was about control systems that ACTUALLY know wheel speed. My purpose for asking was to figure out how to implement a control system for an articulating 4 wheel drive chair. It would require knowing position of each wheel down to about 1.5deg and writing a control law to be programmed into the controller. I do not have an Rnet dongle yet, but hope to afford it soon. I also do not know how to program anything besides parameters into Rnet joysticks and power modules. Does anyone here have a resource for that?
It seems that most chairs just show the commanded speed, so they are OUT of the discussion.
Any brushless system has to know their speed in order to do electronic commutation. So they are IN. Are there any Rnet brushless systems?
Systems implementing https://www.cw-industrialgroup.com/Prod ... der-Module are also IN.
Any info on how to use it?
Burgerman wrote:They decide what it does and how. Its really only used to help track straight with those that cant steer proportionally.
Users browsing this forum: acid_coke and 29 guests
