Any suggestions? Does such thing exist?
It needs to support at least 30° tilt-in-space and have a big backrest. Something like Quickie Iris, but powered.
It does not need to be super lightweight, the main reason for this requirement is that I live on the 3rd floor and we use a Liftkar PT stairclimber, which will not work with a 100kg chair. Up to 50-60kg should be ok.
And also would be good for an able-bodied person to be able to lift it into a car, sometimes some stairs, etc. after removing all easily removable parts (e.g. the batteries or backrest).
So far I found tilt only on the heavy ones, such as most of the Quickie powered chairs have tilt, but not the light ones like Q50.
I was also thinking about Quickie Iris + a power addon like Alber E-fix, but there are some difficulties with this approach, such as it seems like according to our laws I can get the compensation for this addon only if used on some types of chairs.
