Arima wrote:I use a small key/phone bag that slides over the armrest. That way I can switch it to another chair when needed. It also helps protect the pad itself. You can replace the pad on my F3 without replacing the whole armrest. There are 3 parts. The weigh bearing piece that bolts to the frame, then on top of that the plastic trim/retainer which the pad clamps into. Frame, Trim, Pad = 3 parts.
swalker wrote:Here is a parts diagram for the Permobil Corpus 3G armrest that I found online.
The top part, which looks like it is item 36, simply pops off. I have watched a technician do this to my wheelchairs several times, though have never tried it myself.
swalker wrote:I am not sure I remember right, but I think you need to remove the armrest assembly and then release the plastic clips from the underneath side to get the very top piece off.
daveonwheels wrote:oh and no need to remove the armrest. its really not hard
daveonwheels wrote:there are many on ebay.make sure you get the right one. better yet,put armrest pad back on because you didnt break it
Users browsing this forum: No registered users and 74 guests
