rsCPr824
Stage 3 - Constant Voltage , Float
or Maintenance Charging Stage
As explained above, as the charging cur-
rent drops below the preset threshold
(1.5 to 2 amps for SEC-1215UL / SEC-2415UL
and 2.5 A to 3 A for SEC-1230UL), it signals
that the battery is 100% charged.
you would get the green light before morning easy - the problem is how much time you have left before you need to use the chair again - it may not be on float long enough
If the charger has a timer, then it can switch from absorption mode to float mode when the current drops to 0.001C at the 10h rate capacity. In amps. If the current fails to drop to 0.001C amps, then the timer will force the transition to a float charge after no more than 8 hours CV. Another option is to let the battery stay in the absorption phase (14.7V or 2.45 VPC) for a fixed time, such as 6-8 hours, then switch to the continuous float charge.
Burgerman wrote:How old are those odyssey ones?
To attemp to rejuvanate them, to desulfate them, you can discharge fully (to 10.5V). Then charge at say 1A for around 75Ah returned Constant Current - no CV. You can do this by charging at 1A for 75 hours. (3 days). Set the max voltage to around 15.6V on the zxd limited to 1A.
Dont do it more than once or maybe twice in the life of the battery.
If you measure Ah counted out as you discharge it, with PL8 then after this, the capacity should be restored somewhat.
Burgerman wrote:See above. Edited as you posted. I say this as your charger ends too soon. Your battery may be sulfated. A long very slow cc charge to beyond original capacity can reverse some of that. At .5 to 1A the recombination can just about cope. Better to do it 6 days at .5A if time allows. Must start empty. Or you do not give the internal sulfation inside the lead pasted plates a chance to be recovered as it takes time. Dont do this with gel!
The reason this works on an odyssey is that the plates are very thin. So the sulfates inside these pasted plates has a better chance of seeing some action!
This is a ONE OFF!
The USUAL recommendation by odyssey is this:If the charger has a timer, then it can switch from absorption mode to float mode when the current drops to 0.001C at the 10h rate capacity. In amps. If the current fails to drop to 0.001C amps, then the timer will force the transition to a float charge after no more than 8 hours CV. Another option is to let the battery stay in the absorption phase (14.7V or 2.45 VPC) for a fixed time, such as 6-8 hours, then switch to the continuous float charge.
That means 62mA or 8 hours at CV for termination whichever is soonest. Float is only needed to complete the charge if this happens sooner. And/or to store the battery. And 14.7V is prefered. At room temp. Not in siena!
Users browsing this forum: acid_coke, Burgerman, Pierro and 82 guests
