wheelchairer wrote:Has anybody built one of these, A XLR phone charger?
Do you have a parts list, and wiring design?
Burgerman wrote:https://www.wheelchairdriver.com/usb-powerchair-charge-port.htm
Or do as I did a decade ago for the cost of 1 .
Oo that is a good ideabiscuit wrote:Though having said that, the one time the XLR charger might perhaps have been convenient was for my USB heat mat that I got for winter rides, but I didn't think of it.
BTW those links to Lowse don't workslomobile wrote:I've used these chargers https://www.amazon.com/12V-USB-Outlet-V ... B09X165WPS and had good luck with them. There are many similar.
It displays the voltage of the chair battery when you push the button, even when the cover is closed. Generic brackets to fit these are available. Same size as cigarette lighter sockets.
They also fit nicely in any 3/4" nominal electrical box knockout. Nice conduit sized carbide annular cutters are available at the big box stores electrical tool aisle. I think you have metric equivalents across the pond. You can use plastic boxes, or pull junctions as cheap enclosures. If you disassemble a cigarette lighter plug per Burgerman's instructions, you might pot it inside a section of conduit with hot glue.
I found 14AWG 3 conductor outdoor rubber cord on a roll from the big box store fits nicely in the generic XLR connectors from Radio Shack.
https://www.lowes.com/pd/25-ft-14-AWG-3 ... rd/3142963
https://www.radioshack.com/products/rad ... -connector
just use some dish soap on the cable first to get the strain relief grommet to slide on easy.
If I were to do it again, I would integrate a light with it using something like this
https://www.lowes.com/pd/Sigma-Electric ... dy/3389358 to mount the charger, XLR cable, and a LED light in the aluminum cover plate.
https://www.lowes.com/pd/Southwire-1-2- ... 5001872115 clips mounted to the chair and another by the house door. Near a tool battery for emergency light and phone charging during blackouts. Or to supply a little battery power to the chair without inhibit to move the seat/footrests in case the onboard battery dies completely.
Burgerman wrote:Fast charge came along when USB2 went USB3 and instead of 1A you can now get devices that pull up to 3A. So you would need a 3A version which are around a dollar on ebay.
Users browsing this forum: No registered users and 156 guests
