expresso wrote:Time will tell -
cant give lithium away now with no charger to use
i mean a new user - i may give my ADD ON away to try and see etc, but no charger to explain to them - if it cant be charged - wont be used
expresso wrote:Do u have any links to those BMS. U would get ? That may be only option for someone new at this for now
I'm looking at the Overkill BMS
Burgerman wrote:I'm looking at the Overkill BMS
expresso wrote:i am not looking for me - i have PL8
i am thinking of others with none - if i want to gift my ADD ON - one of them - etc, - what would i suggest them use - BMS would be the only logical choice till a solid new charger comes along
Burgerman have you got a better suggestion then or are you and terry2 just having a cross-thread go at each other? For those underprivileged people who have no PL8.
≤50Ah is a possible add-on size, as we know.
Burgerman wrote:Its not that simple. I gave up trying to explain why to you because you either do not read well or dont get it. You might go 1 mile with a "full battery" and stop. And you wont see it coming and wont know why.
For E.G
THIS BMS on aliexpress for e.g if you look at only the 8S 2A 200A BT version.
It does 200A.
It has 2A balance capability. It has all the usual BT and fancy graphics. It has everything you want right?
On the face of it its literally got 20x the balance current of that useless BMS linked to elsewhere on reddit/youtube...
Take a look. https://www.aliexpress.com/item/1005003 ... 4304%22%7D
But that BMS will quite likely end up stopping very unexpectedly! See if you can tell why... This is why knowledge MATTERS.
i cant tell - too much going on that page - tell me why ? and do others do the same or better or worse - so far the bounder BMS is hanging in there but i do have my ADD on with it - so it wont stop either way
expresso wrote:i still have the BMS Shirley got me years ago when i first started - if i didnt do that first - i may not have started a full pack etc, - i got a taste of it this way -
steves1977uk wrote:expresso, I'd avoid an Overkill BMS since they have a tiny balancing current which would take forever on a large pack, but would be ok for an add-on up to 50Ah.
Users browsing this forum: No registered users and 48 guests
