In order to go forwards you need to lean your upper body forwards. And to go back or slow down you need to do the opposite. If you can do this great. If you cant and I cant, not so great. Hence the joystick mod.
StephensonVoice wrote:(And I *did* read the entire thread - several times. I just wasn't sure if there might be some other fatal flaw with self-balancers.)
I would think that one might need to lean a bit farther forward to get the power needed to get over the threshold, and then hopefully the self-balancer would zip up under you quickly enough to keep you off the far wall. Or might that require quick reflexes on my part (you know, like the 'quickly back off on the joystick' one would have to do with a standard chair)? Thoughts?
StephensonVoice wrote:Along those lines, I was curious about how a self-balancer might behave with thresholds along the lines of the standard chair programming heroics to up the power and then knock it down right away so you don't race to the far wall in the next room. I would think that one might need to lean a bit farther forward to get the power needed to get over the threshold, and then hopefully the self-balancer would zip up under you quickly enough to keep you off the far wall. Or might that require quick reflexes on my part (you know, like the 'quickly back off on the joystick' one would have to do with a standard chair)? Thoughts?
Probably I would best correspond with the guy(s) who did the programming I will be incorporating in the rig, to see how they've dealt with this. Oboy. A new version of the 119 page Rpbpteq thread to read!
ex-Gooserider wrote:I have never tried one of the self balancer chairs, and would like to, but more out of curiosity than anything else...
At more or less T-5 level, I have SOME trunk control, but the further over I go the less reliable it gets, so I can easily reach a point where I need to either grab the chair or wave my arm to balance and get me back upright.... I'd be afraid of going to far over to recover reliably... Even if I had a joystick I'd still worry a bit about getting tipped in a hard turn which I'd expect would upset the balance...
A somewhat related datapoint... A couple years ago, I was working with my friend Erik Kondo on making a manual wheelchair accessible hoverboard (we won a first round prize in a Toyota Mobility design competition) One of the problems we found was that it was quite drivable on flat ground or uphills, but downhills were VERY problematic...
Erik would hop his chair up onto the board while holding a wheelie, and drive it by shifting slightly back and forth to tilt the board the way a TAB would do it by flexing his ankles...
The problem on downhills was that the weight shift needed to keep in balance and maintain the wheelie would also tilt the board forward, telling it to go faster, needing more tilt, in a positive feedback loop until bad things happened... In order to tilt the board backwards he would have had to lean forwards, and face plant as soon as the board slowed and he went forward over it... This is something that we were still trying to figure out, without much progress, when we got hit by a 'stealth patent' that effectively ended the project... (Given that I've yet to see a product, I suspect the stealth patent people hit the same problem)
Burgerman wrote:I am not so sure. YOU may be able to. I wouldnt even be able to remain sat in it without a highr back and some proper arms!
I would fall out sideways just sat still. And all the movements I see people making in every video are completely impossible for me.
I think exgoos is very similar - maybe more mobile as T5..
Burgerman wrote:I am T3/T4 complete and cannot do any of what you describe. You sound like T5/T6 incomplete?
Quite apart from this. A joystick offers accurate easy mm perfect positioning. At least once the hovercraft programming has been removed! Weight shift cannot be that accurate no matter what you do. Its clumsy and hard work in comparison. Imagine trying to use your PC mouse to hit a tiny button or highlight a text letter or word for e.g by shifting your body weight! Its just not good enough for accurate positional control.
Users browsing this forum: daveonwheels and 43 guests
